#22301 06/29/02 03:29 PM
golof Offline OP
ok i think my main cat is clogged....is there anyway i can gut it out and fix the problem...im not worried about passing emissions i just want my car to run
thanks
#22302 06/29/02 04:00 PM
9
9
There are lots of threads about this, search the performance threads about this... On a V6 you take them both off the car. The rear one is simple, you just unbolt it from the rest of the exhaust then stick a screwdriver up it and clear it out. The front one, you cut a window on the bottom of the manifold so you can get to the cat material, then weld the window back up. If you have a V6, make sure you fix both of them. -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#22303 06/29/02 08:02 PM
golof Offline OP
thanks so with the main cat that unbolts its completely safe for it to just dig it out? could i just pop a broomstick through it? and i dont have the ability to weld so i dont think i can do the pre-cats unless there is some other way
#22304 06/29/02 10:00 PM
i don't suggest doing your main cat.
if you do, a broomstick will not just "gut" it immediatly. a chisel and vacum is what i used.
be forewarned it cost me $230 to put a new one on (with my uncle as a Ford mechanic)
STD's are like Pokemon...
Gotta catch em' all!
#22305 06/30/02 12:34 AM
Main cat is FAR different than doing the pre cats which does make a few HP for cheap. Leave the main cat alone or replace it with a straight pipe. DO NOT gut it and leave it be. The expansion chamber (left by gutting it) that far down in the exhaust stream will hurt performance.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#22306 07/01/02 12:16 AM
golof Offline OP
brad is it possible for the precats to become clogged? or is it just the main cat that gets clogged? and what kind of noises might they make if they are clogged? and if they are infact clogged i might purchase your already gutted pre-cats....uh...thanks hah
