#22271 06/29/02 04:20 AM
I just insalled a air/fuel ratio gauge "Auto meter 5775" and I was wondering were it should read a WOT confused , I think it has 4 red "Lean",10 yelow "stoich", and 6 green "rich" a total of 20 led indactors.
Also I wanna make sure I got the write wire??
I hooked it to the blue wire. confused
And What fues is best to hook it into?? confused
It doesn't seem to move to much, it never goes past stoich
1998.5 CSVT
K&N Custom Intake
Custom 2 3/4" Magnaflow cat back
Ram HD Power Grip Clutch
Bosch Platnium +
Alpine deck "CDA-7863"
Boston mids
More to come
Stock Sucks!!!!
#22272 06/29/02 04:51 AM
When you have it hooked up right, it will bounce back and forth from red to green at idle (once the O2s heat up). It will then peg up to (EDIT)green (somewhere) when you get on it.
Doesn't sound like you have it right. Unfortunately I have no idea what you need to do. frown
#22273 06/29/02 05:12 AM
You should hook up the sensor wire to a white or white/red stripe on the Contours. At least that is what Autometer said. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#22274 06/29/02 09:52 PM
Does any one else have any experiance with these guages????
Any info. whould be helpful, thanks frown
1998.5 CSVT
K&N Custom Intake
Bosch Platnium +
Boston mids
More to come
Stock Sucks!!!!
#22275 06/30/02 01:48 AM
Hey loco, thanks it worked laugh laugh
At WOT it's max on the rich scale!!
Is that good or bad??
By the way, when I am not accelerating or decelerating it just bounces back and forth from "rich to lean" !!!whats that all about???? confused
1998.5 CSVT
K&N Custom Intake
Bosch Platnium +
Boston mids
More to come
Stock Sucks!!!!
#22276 06/30/02 01:59 AM
Normal operation of the PCM during "closed loop" mode. The O2's will oscillate above and below 0.45 volts (14.7:1, stoich) when the PCM is being most efficient with fuel (and emissions). Mine range from 0.035 V - near 0.8 V, sometimes more when it's doing this. (My S-AFC gives me the exact voltage digitally.)
The O2's on the car are so imprecise at any value away from 0.45 V that as long as a bunch of lights (green) light up at WOT, you are fine. In my car, if I get more than ~0.91 V I foul spark plugs, but other people can run as high as 0.93 or 0.94 fine. You can't really get anything out of the WOT reading with the OEM sensors.
In reality, it makes the A/F meter more bling than functional gauge, but I still think they look cool and want one eventually.
