Posts: 816 |
I know this has been ask before, but I never saw the answer and couldn't find it through searching. The Haynes manual says the transmission has two settings. How do you change these settings?
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 731 |
Overdrive Off button on the shifter controls Sport and Economy mode.
Posts: 816 |
Then it says it also has the O/D button that controls the fourth gear. Not that it controls the modes.
Posts: 1,861 |
I think that the Haynes manual refers to an option only available in Europe.
Jim Johnson 98 SVT
Posts: 55 |
Mondeo MK 1 & 2 equipped with CD4E ATX had a swich next to the shifter that allowed you to change between Econo and Sport mode. Slightly different shift pattern; in Sport mode the downshifts are earlier and the gears are held longer. The switch can be seen in the small lower picture if you look closely: Australian Brochure on Contour.org I don't know if and whe it was available in with the Contour or Mystique, or if the programming and hardware is present in the US version of the CD4E to retrofit it. The OD off switch in the shifter only disables the overdrive (at least in all ATX Mondeos), making 3rd the highest available gear. HTH Joerg
Joerg
Posts: 4,899 |
Turning O/D off makes it hold gears a bit longer, it does not change shifting beyond that.
Posts: 1,974 |
Pressing the O/D button (and turning off the O/D) does NOTHING more than disable the overdrive gear . The main reason for turning off the O/D is for sustained slower speeds and steep hilly roads where the trans would be switching between 3rd & O/D , as this is very tough on the trans . The Euro cars have a Sport/Economy mode selector that changes shift patterns . North American models do not have this feature  .
Posts: 2,961 |
On a driver reponsive transmission like the one in the Contours (which will do whatever your right foot tells it to do), the sport and economy modes are useless gimmicky frills, almost as bad as these selectable gear monstrosities. It may be a European car feature to make the car appear more upscale, but it does not help the performance or function of the car. You hold your foot down, and it will hold it all the way up the tach.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
Posts: 816 |
svtcarboy Member # 946 posted June 25, 2002 09:32 PM -------------------------------------------------------------------------------- On a driver reponsive transmission like the one in the Contours (which will do whatever your right foot tells it to do), the sport and economy modes are useless gimmicky frills, almost as bad as these selectable gear monstrosities. It may be a European car feature to make the car appear more upscale, but it does not help the performance or function of the car. You hold your foot down, and it will hold it all the way up the tach. ummm... isn't the comp set to shift at certain rmps??? and why did every1 go into explaining the O/D, i already know bouts it... the euro shift would allow u yo go into higher rpm range, so maybe if our cars have decent power at higher rpms than those euro dudes can beat us in races.
Posts: 1,445 |
Originally posted by Y2KMondeoSVT: Pressing the O/D button (and turning off the O/D) does NOTHING more than disable the overdrive gear . . on my car turning off the overdrive helps delay the upshifts when im on it hard..under normal driving it shifts the same as overdrive on also the haynes manual is written to cover several car and some of the info is only for the other cars
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
