Page 2 of 3 1 2 3
all the parts are like $45 total.. I have one set of gaskets # F5RZ-9439-B so all you need is another set and that would make 2... the rest I don't remember what they are called frown Ghosst where are you???? we need your infinate wisdom!! :p not to mention tourque specs and order of unscrewing the UIM.. the 22nd .. hmm I 'll double check but I'm pretty sure we can have it at my house.. I got 2 garages and tons of tools.. though if you bring your own with bendable/adjustable ends and stuff the more the merrier..
98 Contour V6 MTX
KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers
Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?"
"Trust me if I could go back and change, I would be stuck in the past" MartinS
EGR gasket should be changed. The part number escapes me at the moment, but the IAC valve gasket is rarely changed. As per Martin's experience, the manifold needs to be scrubbed with a Dremel on the gasket mating surfaces to ensure a proper fit.
As for the torquing; move from the centre outwards, diagonally opposite for the corners. I don't have the picture on-line (already checked) but it's fairly easy. Start with left of centre, then right of centre, then top left, bottom right, top right, bottom left, etc. It's easy to do. Just remember, the toruqe spec is 10Nm or 7 lbs-ft.
I wouldn't mind helping out. I am thinking of doing this myself as well, so any experience that I can gain is appreciated. I don't mean to question you Ghosst but my repair manual showes the following bolt sequence for removal:
2 6 4
1 5 3
Installation is opposite. Torque to 72 - 108 in-lbs (6-9 ft-lbs).
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
Originally posted by timeless420:
Originally posted by cawong11:
[b]Given the time frame it took me to do the manifolds swap in my SVT, give yourself a half a day. This would include the time to do the physical cleaning of the manifolds.
Chris, did you swap them your self or did you do it with your brother. I was thinking about removing the LIM as well to do a better job and prevent bits of carbon from falling in, but I'm not sure it that is too involved and what kind of special tools I would need to disconnect the fuel rail.[/b]
Did it all by myself. When I swapped to the 00 manifolds, it took me a total of just under 2 hours to complete the swap. Figure the rest of the time, I indicated, would be to clean the manifolds.
Between work and the G.F.'s grandparents being in town I'm not sure if I can make it. frown But I'm sure gonna try. I'll post more when I'm sure. Wish Dana wasn't to busy drinking tea to cime out to play. I mean after all he's only a pond or so away. :rolleyes: laugh
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
BTW when we are this deep into the intake system is it easy to get at the fuel injectors to clean them?
If the lower is coming out, then the injectors come with it too. The job will go a lot easier removing the lower if you get those clamps to release the fuel injector rails from the supply and return fuel lines.
Well, if someone wants to do the rear disk conversion for me too, they are more than welcome laugh
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
2 6 4
1 5 3
The torque specs are right, 7lb-ft. As for the removal and installation order, I'm not entirely sure (without the picture) but I beleive it's more like...
6_____1_____3
4_____2_____5
(for tightening)
1_____6_____4
3_____5_____2
(for loosening)
Generally, the idea is to seat the manifold, then tighten it down again without putting too much pressure on the edges to avoid marring the surface. I may be home for a day or two next week, if I am, I'll upload the pics then.
ok this is what we need ppl (that want to do it)
UIM Gasket (1pair)(that means X 2)
TB Gasket
EGR Gasket
and a Tourque wrench who ever has one..
hopefully ppl will still want to do it next week laugh
98 Contour V6 MTX
Page 2 of 3 1 2 3
Moderated by  Gerald_dup1, mbb41_dup1
