Posts: 1,040 |
Posts: 581 |
I actually got mine off another CEG member who bought is a while ago in a group buy. Wouldnt have been able to help with that.
Posts: 1,040 |
Originally posted by horseydug: I have ordered new metal Tredex pump via East End Automotive Distributors .... Edit @2:15pm May 14/02: Pump arrived at noon today, curious the casting, shaft and pulley are stamped GMB Japan. Cost was $126 Cdn + tax (no casting charge since it's new, not reman). I won't lengthen post by reciting details but the telephone customer service at this "cubby hole of a store front" was amazing. I'll be back. .... How prophetic! Pump on my '98 failed Friday, autopsy performed yesterday which confirmed diagnosis, so I'll be ordering another first thing tomorrow. Two wp failures in May on cars with one year age and 20k km difference.
Posts: 1,083 |
I'm confussed. That was the plastic impeller version that failed correct?
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 85 |
Newbie Question:
What is a waterpump and what happens when it goes? Is there a way to tell when it goes
Thanks! Derek
1999 Contour Sport SE (Black) Duratech V6 MTX Brullen Cat-Back Exhaust *LOUD* S&B Powerstack Filter Eurolite Xenon bulbs
Posts: 334 |
When water pump goes kaboom usually prequils the engine going kaboom as well..
symptoms:engine temp going through the stratosphere
Solution: switch to new waterpump with metal impellar cost: $60US Installation: can be done by yourself
If not done: cost of replacing enging = $5000
:rolleyes: cheers
98 Contour V6 MTX KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?" "Trust me if I could go back and change, I would be stuck in the past" MartinS
Posts: 1,040 |
TonyD Yes. I had the black plastic OEM pump go on my '97 on May 10, replaced with metal Tredex. Now my '98 black plastic OEM has gone and I ordered another metal one this am which will hopefully arrive tomorrow.( Edit: Pump arrived 4:30pm from Tredex in Quebec)
Derek D Pump circulates coolant(water + anti-freeze) around engine/heater core/rad. When plastic impeller breaks, no forced circulation therefore engine overheats. Same thing happens if your water pump drive belt fails or a hose ruptures. Latter most serious since you lose coolant, but generally you would have warning -- lots of steam! Pump (and belt on v6 Contiques) failure unfortunately is only detected via temperature gauge rising rapidly.
Posts: 407 |
Do you have a phone number? .. couldn't find them in the yellow pages. thx
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 1,040 |
Sorry, should have stated in my post above.
East End Automotive Distributors 1033 Toy Ave Unit 6 905-686-7778
Brock Rd/401 area in Pickering
South on Brock, east on Bayly, north on Toy (at Tim Horton's). Open daily 'til 6:00pm, Sat 'til 3:00pm. No visa, cash or m/c (deposit req'd)
Posts: 407 |
Thx ... placed my order this mornin'.
