Posts: 151 |
Well the svt is going on the dyno tonite to see the gains from the MSDS Headers.
830pm at the usual place if anyone is interested.
Zach
2001 VW Golf GLS 1.8 Turbo 220hp/260tq Porsche Cup 3s rims w/225 45 17 tires Oettinger Grille, Votex Rear Spoiler, and way more mods
Posts: 1,050 |
So did you end up making it to the dyno? We need numbers...hehe
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
Posts: 1,421 |
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 151 |
Made it but the numbers are screwed with the new tires. Damn I knew I should have baselined after the new tires.
Zach
Posts: 1,421 |
Posts: 407 |
Is your KKM dirty??
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 151 |
LOL, no it is clean  The one really good thing that came from the dyno was the chip is working as it should again. I'm seeing peak increases of 5hp and 8lbs. It also made the curve way smoother and the rev limiter was moved a little. The other will be when i change from the the ypipe and cat to the msds setup. We'll finally end the debate over which design is better.
Posts: 1,421 |
2xtrms what r u doin with your cat n y pipe when u get the msds or is this also top secret
Posts: 1,050 |
Zach, Whats your computer code? It looks like me and you have one of the better and functioning chips with very good performance increases. Also, what octane do you run regularily? Any pinging or other problems? Originally posted by 2XTRMS: ...
The one really good thing that came from the dyno was the chip is working as it should again. I'm seeing peak increases of 5hp and 8lbs. It also made the curve way smoother and the rev limiter was moved a little. ...
Posts: 1,421 |
through further investigation i think i found it
