Posts: 153 |
Originally posted by ibub: This one looks suspiciously identical to the pump I just bought from NAPA for $51.00. Available either online or thru their stores :rolleyes: [/b]Did the NAPA one have the metal blade? And do you have the part #? I'm gonna get this pump someday in the near future. I just bought my SVT with 44K and I don't want to be stranded with an exploded impeller.
Administrator
Administrator
Posts: 5,037 |
The white "plastic" one is fine. It's the black plastic that sucks.
I have the white plastic one on mine now. This is also the same one on the Cougar's that have had no problems... yet.
Posts: 153 |
Originally posted by Chris Hightower: The white "plastic" one is fine. It's the black plastic that sucks.
I have the white plastic one on mine now. This is also the same one on the Cougar's that have had no problems... yet. Thanks for the info. Note to self: White plastic or metal impellers.
Posts: 98 |
I have a white plastic one if anyone needs one! $20 and it is yours. It is only the impeller half. You can have the other half but it is broken  The belt tensioner part was broken off. It is from a 2000 SVT contour with 11K miles on it.
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed: svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
Posts: 153 |
Originally posted by Blackcoog: I have a white plastic one if anyone needs one! $20 and it is yours. It is only the impeller half. You can have the other half but it is broken The belt tensioner part was broken off. It is from a 2000 SVT contour with 11K miles on it.Thanks for the offer, but I'm gonna pass.
Posts: 897 |
MOTHERF%$#ER!!! I ordered the part from AutoZone, went and picked it up today...B125-1910, uses a damn black plastic impeller now...why can't I get a metal one!!!!!!! I had the white one yesterday for $47, it was better plastic. I went thru all the friggin trouble of finding the part and ordering it and getting a ride to and from work, I can't wait any longer to get it fixed. I'm royally pi$$ed!!!
1998 T-Red CSVT (1492 of 6535) Born on 5/30/97 KKM 4.6L TB with custom "Throttle Optimizer" Bassani Exhaust NP-Tuning Sniper Intake Pipe Fog Light Mod with 885's Clear Corners Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
Posts: 897 |
Problem solved, and for less money. NAPA is the place now, same part number 125-1910, metal impeller, $57.00. I'm much happier than the post above.
Posts: 153 |
I just jotted down the part #. Thanks.
Posts: 42 |
Originally posted by Dandridge: Problem solved, and for less money. NAPA is the place now, same part number 125-1910, metal impeller, $57.00. I'm much happier than the post above. I just got mine at NAPA. $51.99, $55.37 after tax. It was an easy install, took about 90 minutes.... 30 of which were trying to scrape off the old gasket from the original waterpump. Not much room in there for long fingers like mine ;-)
Posts: 897 |
Yeah, thank goodness for my little socket set.
