Posts: 407 |
same as mine alessandro - sfg0 - yet mine never increased redline Originally posted by SilVer bulleT: Zach,
Whats your computer code? It looks like me and you have one of the better and functioning chips with very good performance increases. Also, what octane do you run regularily? Any pinging or other problems?
Originally posted by 2XTRMS: [qb]...
The one really good thing that came from the dyno was the chip is working as it should again. I'm seeing peak increases of 5hp and 8lbs. It also made the curve way smoother and the rev limiter was moved a little. ... [/QB]
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 151 |
Mine barely moved the rev limiter, its at 7k instead of 6750
And it is SFG0
2001 VW Golf GLS 1.8 Turbo 220hp/260tq Porsche Cup 3s rims w/225 45 17 tires Oettinger Grille, Votex Rear Spoiler, and way more mods
Posts: 151 |
Well the MSDS collector is in and it feels much stronger. When I get my car back from getting the tranny rebuilt i'm gonna break it in then dyno it to see which gives better #'s
Posts: 1,050 |
What were your original numbers when you put the headers in? You never gave us this and it doesn't help not knowing...A point of reference would be good... Originally posted by 2XTRMS: Well the MSDS collector is in and it feels much stronger. When I get my car back from getting the tranny rebuilt i'm gonna break it in then dyno it to see which gives better #'s
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
