Posts: 153 |
Thanks guys for your help. I'll check out the door jam. I have a chrome base antenna also so I really think I have a 98.
One of these days I'll get a hold of SVT for the cert.
Posts: 1,493 |
"The change to the 98 1/2 was 2/2/98."
That is for the SVT models, not the SE/LX's. Fall of 97, the 1998 models were reconfigured.
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 1,861 |
Also the power antenna base on the E0 is teardrop shaped, while the E1 is round.
Jim Johnson 98 SVT
Posts: 3,419 |
Got a stand alone clock? Probably (but not really definitely AFAIK) a 98.
I'm not sure what you mean by newer 3rd brake light. Do you mean it's in the spolier instead of the rear window? When I ordered mine (Jan 97), no factory spoiler was available, but that may have changed later on (but before 2/2/98). If you have a factory spoiler, then you won't have a rear window brake light no matter what vintage it is. If it was added later, you probably would have both.
Posts: 153 |
Originally posted by PA 3L SVT: Got a stand alone clock? Probably (but not really definitely AFAIK) a 98.
I'm not sure what you mean by newer 3rd brake light. Do you mean it's in the spolier instead of the rear window? When I ordered mine (Jan 97), no factory spoiler was available, but that may have changed later on (but before 2/2/98). If you have a factory spoiler, then you won't have a rear window brake light no matter what vintage it is. If it was added later, you probably would have both. By the 3rd brake light, I meant it's a long thin light in the back window instead of a squarer unit, if that makes any sense. I thought that was one way to tell, but After reading the above posts, I think I really just own a 98.
Posts: 1,861 |
The spoiler wasn't a factory option until 2000. Many were dealer installed before then.
Jim Johnson 98 SVT
Posts: 63 |
I have a 2000 se zetec from what I understand in 2000 only se sports were avalable with the duratec but mine has no side skirts and it had se badges on the front fender and a zetec I am confused
2000 SE Zetec ATX,17" Fundametal rims with 205-40-17 tires, Custom exhaust,Clarion dxz715 head unit, Pioneer 3way 6x8's,5" lcd TV, Pyle DVD/MP3/TV-Tuner cd player, clear headlight corners, side markers, headlight strobes,white guages,woodgrain kit,guage pods,
Posts: 1,493 |
New 2000 SE "non sports" could be ordered by fleets only and with a 4 or 6 cylinder engine. There were many put into the used car market last year. "2000 SE expert"
Posts: 1,196 |
Originally posted by Dan Pope: My 98.5 SE has no sideskirts, but does have 24v badges. Not "sport" model. Is the build date after 8/97? It's a 98.5 Also the power antenna base on the E0 is teardrop shaped, while the E1 is round. Got a stand alone clock? Probably (but not really definitely AFAIK) a 98. Now I'm very confused. According to these quotes, I have a 98.5 SE. But I have the Duratec V6 engine (no it's not an SE Sport), stiffer suspension, and standalone clock like the regular 98 SEs have. I have a 24V badge on my trunk, and the sidemarkers say "SE". No side skirts. Built 11/97 (according to the sticker on the driver's door). I had originally been told the SVT transition date, and that is why I believed I have a 98. Is mine a unique model (i.e. possibly ordered in 1997, and arrived in late 97)? I do remember someone on this board that has a 98.5 GL because it was ordered. Or do I now have to change my screen name? What do I have?
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
