Originally posted by Rob T.:
What modifications should I make, as a student with a limited budget, to try and make this car cool and enjoyable? Thanks guys!
Cool and enjoyable?
Well, there are a number of things you can do that are relatively cheap, to free..
You can:
1: get the drop in K&N that gdub mentioned. IT will help with the air intake and you will get a little more in the "go mods" dept.
2: Go for aesthetics, which will provide you with a lot more "enjoyment" for your dollar, I think!
Try:
A: Replacing the headlights with the clear/blue bulbs Model #'s 9005, and 9006 (for highs/lows"
B: Tint.. makes a world of difference, both in the appearance and climate. 'nuff said.
C: remove the door dings, AKA knauberize. (search, you will find LOADS of info, and pics. a free mod that works wonders on looks.
D: do the "Fog light" fix. Another nice appearance mod, free!
E: While you are knauberizing, de-badge the vehicle, too...
F: Go for a grille mod. Home depot has the "gutter guard" for about $2.00 a sheet. more than enough.. a little elbow grease, and a pair of wire cutters, you are set..
3: one I would suggest, get an ALARM.. yes, not free, but a WORTHWHILE investment. if your car is an ATX (automatic) you could get the "remote start" feature added, too.. (even an MTX CAN have it, but more expensive, I believe!) THAT is a nice feature!
Try searching for MODS, or go to the main CEG page, and go to the MODS section to see a few others. Hope this helps in your begining ventures!
HTH
Ray
P.S. Email me if you have any other questions!
