Posts: 352 |
Hi Paul, This is kinda long...first the link to some photos... A/C switched photos I wired a relay and switch into the A/C circuit behind the HVAC selector panel. (The first switch in the pics is not the one I ended up using.) I tapped the GREEN/red wire for a power source for the relay. The GREEN/orange wire is a ground wire for the A/C clutch and that wire is cut and now connected to and operated by the relay. The switch I used was from a 1981-2 Datsun 200SX. The photos should help. The a/c switch will run the compressor only when it is depressed and the selector knob is in one of the four a/c positions. The light in the switch, however, will come on anytime it is depressed and the selector knob is moved to any position other than "off". On the 1981-2 Datsun 200SX switch, there are three wires, the two upper wires are to the contacts that will operate the relay and the third lower wire is for the light. The wire for the light goes directly to ground along with the ground for the relay. As I recall, it made a difference in the operation of the light, which wire from the switch was wired to the GREEN/red "hot" wire. I don't recall which one, sorry. You will really like the switched operation...it's great! ...Ed
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Administrator
Administrator
Posts: 5,037 |
Thanks Bill!!! I just got my DVD today and MAN is it neat!
Posts: 2,523 |
You're already shipping them, Bill? If so, I'll be anxiously checking the mail
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 82 |
Bill,
Are they still available? I am interested in some.
'98.5 Contour SE - Zetec Powered '00 Focus SE rims with Toyo FZ4's Rickbrook Shifter Knob Bullit Gas Door Accel Coil with Ford Racing Wires KVR Cross Drilled Rotors with KVR Carbon Fibre Pads
Posts: 4,585 |
Bill,
If you have found a way to get the 97+ Fords onto a disc, I'll take one. Paypal empty right now so I'll transfer funds and have it ready in a couple days. A lot of Ford's in my family as well.
Posts: 2,523 |
Bill - got mine yesterday.
Thanks!
Posts: 59 |
Received my DVD today. Had a little trouble installing it  , but after cleaning the disc, everything worked out great  . Thanks Bill! James
96 Mercury Mystique - Zetec ATX Mods? Yeah, those cost money...
Posts: 294 |
Bill,
So did you manage to fit 97+ on one DVD ?
Regards, Kirill 98.5 Contour SE Silver Frost (powered by Duratec 2.5L) Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i \_ Blaupunkt ODx694
Posts: 3,636 |
I haven't seen anything yet. But I have hope, Bill is a busy guy.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 656 |
Sounds like Bill going to have to get creative for the 97-02 manual? I"ve been told (never tried) using WinZip, zip it up and use the split function. in the menu is several choices the last two are 650meg CD and other. Since this is new ground for WinZip it may or may not fly. It's a computer guru thing to come with something, dogone copyright/whereever Oh well the rich have to have someway to stay rich :rolleyes: Of course what will be like to use?? edorfox's DVDdemystified website, tried reading through that, man I don't own enough "pocket protectors" to absorb all that. \ Gone Fishin!!!! Paul N8BUU http://www.dvddemystified.com/dvdfaq.html
