Posts: 209 |
Here are the links to purchase the 92-96 and the 97-2003 Service manual on DVD-rom. They are going to be $20 each, and these are COPIES.
1992-1996 All Ford/Lincoln/Mercury products.
I have run into a problem with the 97-2003 discs. It seems the 92-96 DVD is only 3.5gb in size, no problem for the 4.7gb discs. But the 97-2003 is 6.3gb in size. So am trying to figure a way out of this. I will update everyone ASAP.
Posts: 908 |
All set paid. Thanks a lot Bill!!
Mike michael@mklaro.com
Mike | 98 Silver CSVT
Posts: 352 |
Bill,
Please let us know when you get the 97-2003 discs zipped, or whatever, successfully. I would certainly like to have one.
...Ed
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Posts: 3,419 |
*sigh* I wish I had a DVD drive.
Posts: 1,461 |
I think DVD drives are going for $60 or so now..
Brian
Posts: 3,636 |
Originally posted by PA 3L SVT: *sigh* I wish I had a DVD drive. They are consumable parts at work. If I order one for a service call, and don't need it, I can't return it. No, I'm not going to order a bunch of DVD-ROM drives. Besides, not many of you have SCSI in your systems at home. TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 668 |
Bill, Can your dvd burner use double sided discs? If so you can get discs that hold 9.4 gigs (I think that is the correct amount).I'm sure they cost a little more but might be easier for you to burn. Just a thought. Thanks Stan
98.5 SVT#6092 of 6535 B/MNB Born on date 5/22/98 Y2K Suzuki GSXR 750 Y/B with 140.6HP
Posts: 2,061 |
i'd be interested in this.
Dave Andrews Black&Tan 2000 SVT 225 of 2150 Bassani.. UNCORKED davelandrews@comcast.net "Nothing is so firmly believed as what we least know." -Montaigne
Posts: 352 |
[/QUOTE]They are consumable parts at work. If I order one for a service call, and don't need it, I can't return it. No, I'm not going to order a bunch of DVD-ROM drives. Besides, not many of you have SCSI in your systems at home. TB[/QB][/QUOTE] I do! I do! Can I send you my address?? ...Ed
Posts: 9 |
Bill, I still would like a copy of the 97 - 03, no matter what format you can copy it onto. Thanks!!
98 CSVT----All stock, but big things are coming!
"You can spend all the money you want, but if you can't drive you'll still lose!"
