Posts: 62 |
Would someone please run an Oasis Report on this vin: 1FALP67L1TK205997. Thank you.
96 Black SE 2.5L V6 ATX
Posts: 1,861 |
It looks like there is an error in the VIN. Check the VIN and I'm sure that someone will try again.
OASIS RESULT: 1FALP67L1TK20599 . 06/11/2002 00:19:01 Errors VIN NOT FOUND VERIFY ENTRY FIELD SERVICE ACTIONS *EXTENDED COVERAGES NO ESP INFORMATION AVAILABLE REPAIR HISTORY NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FALP67L1TK20599
Somehow the entire VIN did not transfer. I hope this looks better.
OASIS RESULT: 1FALP67L1TK205997 . 06/11/2002 00:23:20 VEHICLE INFORMATION VEHICLE DESCRIPTION 1996 CONTOUR BODY STYLE 4 DR SEDAN SE ENGINE 2.5L EFI DOHC ENGINE CALIBRATION 612BR10A TRANSMISSION CD4E AUTO TRANSAXLE AXLE CODE 4G GENERAL WARRANTY INFORMATION WARRANTY START DATE 08/23/1996 BUILD DATE 04/26/1996 SALE MILEAGE WARNING MESSAGES LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE FIELD SERVICE ACTIONS 01M07 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE HEATER BLOWER SWITCH - COVERAGE FOR 10 YEARS FROM WARRANTY START DATE OR 150,000 MILES OR 12/31/2001 IF VEHICLE HAS 150,000 MILES. COVERAGE TRANSFERS TO SUBSEQUE NT OWNERS 99M03 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE UNDER HOOD WIRE HARNESS - ADDITIONAL COVERAGE 99M07 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE HEATER BLOWER SWITCH, RESISTOR AND ATTACHED WIRE CONNECTORS *EXTENDED COVERAGES NO ESP INFORMATION AVAILABLE REPAIR HISTORY
-------------------------------------------------------------------------------- 10/09/2001 DEALER: Vancouver Ford Inc WARRANTY CLAIM NUMBER: 369509 ODOMETER: 066973M PART NUMBER PART DESCRIPTION QUANTITY LABOR OP CONDITION CODE CONDITION DESC F7RZ 18578DA SWITCH ASY-HEATER 001 01M07B F5RZ 14A411AA WIRE ASY MAIN JUMPER 001 66973 BURNED HEATER BLOWER SWITCH AND CONNECTOR. 0.5 REPLACED HEATER BLOWER S WITCH AND CONNECTOR PER 01M07.
END OF OASIS REPORT FOR 1FALP67L1TK205997
Jim Johnson 98 SVT
Posts: 956 |
Well... I don't want to be abusive... but...
Would you also run one for me ??
It is really important... I am buying a beater...
thanks !!
JM1BG2246N0508240
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 731 |
Could you run one for my 'Tour too? 1FAFP6631WK217621 Thank ye kindly
Posts: 731 |
ttt!
Posts: 1,861 |
thanks !!
JM1BG2246N0508240 Oasis is a Ford program. It does not provide a data bank for non Fords.
Jim Johnson 98 SVT
Posts: 1,861 |
OASIS RESULT: 1FAFP6631WK217621 . 06/12/2002 00:51:15 VEHICLE INFORMATION VEHICLE DESCRIPTION 1998 CONTOUR BODY STYLE 4 DR SEDAN SE ENGINE 2.0L EFI DOHC ZETEC ENGINE CALIBRATION 804AR10A TRANSMISSION CD4E AUTO TRANSAXLE AXLE CODE 1A GENERAL WARRANTY INFORMATION WARRANTY START DATE 11/29/1997 BUILD DATE 11/14/1997 SALE MILEAGE WARNING MESSAGES LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE FIELD SERVICE ACTIONS 01M04 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE FUEL PIPE FILLER VALVE ASSEMBLY - ADDITIONAL COVERAGE TO 10 YEARS SERVICE OR 100,000 MILES FROM WARRANTY START DATE WHICHEVER OCCURS FIRST 01M08 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE FRONT SPRINGS - COVERAGE WILL BE IN EFFECT FOR 10 YEARS OR 150,000 MILES FROM WARRANTY START DATE - PLEASE NOTE: SVT VEHICLES ARE NOT ELIGIBLE 99M07 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT. PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE HEATER BLOWER SWITCH, RESISTOR AND ATTACHED WIRE CONNECTORS *EXTENDED COVERAGES NO ESP INFORMATION AVAILABLE REPAIR HISTORY
-------------------------------------------------------------------------------- 04/03/2002 DEALER: Bob Ferrando Ford Lincoln-Merc WARRANTY CLAIM NUMBER: 032233 ODOMETER: 057023M PART NUMBER PART DESCRIPTION QUANTITY LABOR OP CONDITION CODE CONDITION DESC F8RZ 5304AA KIT-FRT PRING RR SHA 001 01S23B RECALL 01S23
END OF OASIS REPORT FOR 1FAFP6631WK217621
Jim Johnson 98 SVT
