Posts: 3,223 |
The site will be moving soon anyway. Matt is loosing his T1 line!
-Andy
Posts: 587 |
Moving? As in??? Malfunction.. Error.. Further Elaboration Required.. What's gonna happen to CEG? Why's he losing the T1? Cost? Thanks.. Ray
Posts: 3,180 |
He's getting laid off soon, and the T1 was provided by his old company.
Posts: 3,419 |
I've been wondering what was going on with that (losing Matt's T1).
Posts: 249 |
If contour.org will be in need of a new host then I recomend www.cyberwings.com. They offer VERY cheap, reliable hosting.
~~~~~~Mike~~~~~~ Silver 2000 Contour SVT # 1200 of 2150
Posts: 442 |
Does anyone have bandwidth reports on the CEG usage. If it is not maxing out the T1, then I could host it where I work. We run a 3 mb's connection.
1999 Silver Frost SVT #2412 of 2760 DOB - 7/30/99
MODS:
BAT Inlet Pipe /w Monster Flow Filter, Rear Strut Brace, H&R Sport Springs, Koni Sport Struts, Panasonic CPQ-DF800u, Baer Brake Kit, Brembo Slotted/Crossdrilled rotors for rear brakes, rear KVR Pads, ASA JS6 17" w/ S-02 Pole Position, B&M Shifter, 22mm Rear Sway bar, Bassani Exhaust. SoundStream Rubicon 604 Amp, 2 SoundStream Class A 5.2 Amps, 2 SoundStream SPL 12" Subs, SoundStream SVX2 Crossover, Rockford Fosgate Capacitor.
Posts: 731 |
If need be, I'll donate as much as I can; this site has been a GREAT help to me and I met some great people  There's no reason I couldn't return the favor!
Posts: 1,493 |
How about deleting useless posts? I try to delete mine as time allows. Also, locked theads that turn into 'cat fights'?
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Master P
Master P
Posts: 5,455 |
Originally posted by sboardsvt: Does anyone have bandwidth reports on the CEG usage. http://www.contour.org/usage/ Call it 100gigs/month.
Posts: 82 |
mine computer gave me a dial up error everytime i tried to get on.. it said that i was not connected to the net and i needed to dail up.. but i have a cable modem and im always connected. After the search for the site timed out, it assumed the whole connection was down and tried to connect with the dialup.
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
