Page 2 of 2 1 2
#192243 04/11/01 11:03 PM
Atmospheric conditions matters. And so does height above or below sea level. And running on as little gas as possible is to your advantage. Water weighs 8lbs a gallon, and I dunno what gas weighs, but full gas tank would slow you down. And don't rely on published performance figures. Those are done under weird conditions usually hard to duplicate.
Dan Parmelee
TheContourGuy@aol.com
95 SE ATX
KKM
24V HIGH OUTPUT badging
SVT E0 wheels/tires
yellow calipers
CEG sticker
OF's TH fix
HyperWhite high beams
CoolBlue low beams
drilled metal pedals
faux metal grille
http://hometown.aol.com/thecontourguy/contour.html
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#192244 04/11/01 11:05 PM
By the way, 17.45 is really bad for an SVT. My 95 SE with an AUTOMATIC can run a 17.8! Also, did you powershift? And a short throw might shave a bit of time off.
Dan Parmelee
95 SE ATX
KKM
SVT E0 wheels/tires
yellow calipers
CEG sticker
OF's TH fix
CoolBlue low beams
faux metal grille
Dan Parmelee
#192245 04/12/01 12:05 AM
With these Transmissions in these cars, I would only recommend power shifting if your car is still under warranty.
Short-throw would work, but when shifiting just shift as fast as your ass can shift, if your on a stock shifter.
Jay (Intersection Killer)
00 'BARTENDER! A Black&Tan' SVT Contour
Home Sweet Home
www.SVTperformance.com
Jay
02 SVT Lightning
www.SVTPerformance.com
#192246 04/12/01 08:48 AM
9
98.5SVT Offline OP
9
i did power shift, and i have a 100,000 mile warrenty so i'm alright in that aspect. i also just got a new trans put in a week before i took it to the track. i put about 700 miles on before though. i had less then a half a tank of gas too. something is wrong with the car. has to be, cause black98svt ran almost 2 seconds better then me and we were at the same track. well im taking it to the dealer tomorrow, so we'll see what happens.
98.5 black svt.
JD Custom Exhaust.
"DOWNWARD MOTION" windshield banner.
15.60 @ 87.86mph. 1/4 mile
#192247 04/12/01 07:45 PM
Ok he didn't tell me he put that back on, last I knew he took it off.
Originally posted by Black98SVT:
RTS...J has a cold air set up on his ride. It is a nice Alum piece that locates the air filter down and up front in the engine compartment. He had some great launches Sun! I was talking about the guy that came with the Cobra R and a Lightning.
Ryan
98.5 Silver Frost Contour SVT 5979/6535
Born: May 15, 1998
~Tweaked Airbox, SRP Racing Pedals w/SVT engraved, Saleen Dead Pedal, Fog Light Mod,B&M Shifter, Ford Door Sill Protectors~
**Mustang Dead Pedal on the Way!!**
84 Thunderbird 5.0
ex 93 Modded SHO
SVT Performance.Com
Ryan
98.5 Silver Frost Tour SVT 5979/6535
Born: May 15, 1998
Some Mods, still not fast enough..
90 Black SHO
SVT Performance.Com
#192248 04/12/01 07:45 PM
Ryan
Born: May 15, 1998
84 Thunderbird 5.0
ex 93 Modded SHO
SVT Performance.Com
Ryan
Born: May 15, 1998
90 Black SHO
SVT Performance.Com
Page 2 of 2 1 2
Moderated by  hetfield_dup1, Loco4G63
