Posts: 42 |
I was just at the byron race way on 4/8, i saw all the lightnings and R/t's, by the way, that 2K Cobra R. ran a mid 13, in my eyes that's a waste of $65,ooo. anyways, my problem is that my 98.5 contour SVT, ran a 17.45 in the 1/4 mile. my brother ran it, and he ran a 17.62. so i know that it wasn't my driving. i guess i'm asking what could be wrong? we thought my car was running wrong a week before, so i went out and replaced the fuel filter, it made a difference but not that noticeable. I'm thinking that a valve isn't opening up or something, do you guys have any ideas?
98.5 black svt. JD Custom Exhaust. "DOWNWARD MOTION" windshield banner. 15.60 @ 87.86mph. 1/4 mile
Posts: 1,089 |
The secondaries in the intake manifold may not be opening all the way. It could also be a partially clogged cat.
------------------ '98.5 Mystique GS ATX/re-contented door lights/K&N Filter/Energy Suspension Sway Bar Bushings/Mintex Street Pads/high-beam bulbs in low-beams/Pioneer DEH-P3100 receiver/Pioneer TS-A6855's in all doors
Justin '02 Ranger Edge ext cab Retired: 98.5 Mystique
Posts: 128 |
Hey bro, don't feel too bad. I was there running too and as the day went on and the temps went up, my times got worse. My best 1/4 was in the upper 15's. Couldn't seem to get the 60' times down (best 2.4). Seemed to bog a little when tires were at 25psi. Left between 2500-3000 rpm. Maybe I should try around 3200 next time. My ride is stock (for now) and the other two S-tours that were running faster had a cold air set-up. I think if we get the KKM system and change out that F-ed up Y-pipe we should be in the high 14's to low 15's (to be installed and track tested soon!).
[This message has been edited by Black98SVT (edited April 10, 2001).]
1998 Black SVT Contour Born on 4/23/97 #433 KKM intake & No res 1996 Mystic Cobra #544 VP www.midwestfords.org
Posts: 42 |
DID I TALK TO YOU THERE? DO YOU HAVE THE SPOILER? WAS YOUR GIRLFRIEND THERE? ANYWAYS, I SHOULDN'T HAVE TO PUT ANY MONEY INTO THE CAR TO GET IT INTO THE 15'S. IT'S SUPPOSED TO DO 15.4 STOCK RIGHT? I KNOW THAT'S WITH A PRO DRIVER, BUT THERE IS NO REASON THAT MY CAR SHOULD BE RUNNING IN THE 17'S.
Posts: 128 |
Yes, that was me with the 98 Black SVT, tinted windows, spoiler & plates: MISMYV 8 Stock 1/4 time is listed at 15.7 One of the other guys there had a KKM intake and a B&M shifter and minor exhaust mods and said his best time was 15.4 Have you had a Check Engine light pop up? I did last week and had to change out one of the o2 sensors (only has 34K miles). I changed out the part and re-set the computer and the car is running very strong. You might want to think about checking out a few things..plugs, wires, air and oil filter, run some injecter cleaner and a couple of tanks of high grade gas (93 octane or better) through her and re-set the computer. Unplug the battery, hold the brake down for a few seconds to drain the charge, and let her sit for a couple of minutes. Re-connect the batery, start the car and let her run for about ten minutes and don't touch anything. Let the computer re-set its parameters, then take her out for a run. Let me know if that helps!
------------------ 1998 Black SVT Contour Born on 4/23/97 #433 1996 Mystic Cobra #544
Posts: 42 |
THANKS BRO, I APPRECIATE THAT, I WILL DEFENITELY TRY THOSE OUT. ARE YOU GOING TO THE MEET ON MAY 6TH? IF YOU ARE LET ME KNOW THE DETAILS, SO I CAN MEET UP WITH YOU GUYS. AGAIN I SAY THANKS, I'LL TRY THOSE FEW THINGS OUT AND LET YOU KNOW WHAT HAPPENS, IF YOU HAVE ANY OTHER IDEAS, I'M ALL EARS.
Posts: 592 |
Actually J ran a 15.4 @ 87 there BONE STOCK so, it may also come down to driving, tire pressure, etc. Or like some else said your secondaries which I've heard people have problems with them. Originally posted by Black98SVT: Yes, that was me with the 98 Black SVT, tinted windows, spoiler & plates: MISMYV 8 Stock 1/4 time is listed at 15.7 One of the other guys there had a KKM intake and a B&M shifter and minor exhaust mods and said his best time was 15.4 Have you had a Check Engine light pop up? I did last week and had to change out one of the o2 sensors (only has 34K miles). I changed out the part and re-set the computer and the car is running very strong. You might want to think about checking out a few things..plugs, wires, air and oil filter, run some injecter cleaner and a couple of tanks of high grade gas (93 octane or better) through her and re-set the computer. Unplug the battery, hold the brake down for a few seconds to drain the charge, and let her sit for a couple of minutes. Re-connect the batery, start the car and let her run for about ten minutes and don't touch anything. Let the computer re-set its parameters, then take her out for a run. Let me know if that helps!
------------------ Ryan 98.5 Silver Frost Contour SVT 5979/6535 Born: May 15, 1998 ~Tweaked Airbox, SRP Racing Pedals w/SVT engraved, Saleen Dead Pedal, Fog Light Mod,B&M Shifter, Ford Door Sill Protectors~ **Mustang Dead Pedal on the Way!!** 84 Thunderbird 5.0 ex 93 Modded SHO SVT Performance.Com
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 128 |
I will be at the meeting on the 6th if it is at Cue. I will already be there for the MidWest Racing club meeting...works out great that way  Bring your sub set up if you can and I will check it out, but I think it sounds a lot bigger then what I am looking for. RTS...J has a cold air set up on his ride. It is a nice Alum piece that locates the air filter down and up front in the engine compartment. He had some great launches Sun! I was talking about the guy that came with the Cobra R and a Lightning.
Posts: 1,932 |
When I first got my CSVT, I ran a 15.4 in the 1/4.. i think i can do a better time than i had before because i drive better...
99 svt contour -its fast. period. 91 mustang gt -its faster. period. 86 Buick Grand National - its way faster, double period!
Posts: 350 |
BTW How much gas where you guys driving on? I had almost 3/4 tank! That was nutz...who knows how much a 1/4 of tank good improve times...next time ill drive around the parking lot for a few xtra hours. ------------------ Jay (Intersection Killer) 00 'BARTENDER! A Black&Tan' SVT Contour Home Sweet Home www.SVTperformance.com
