Posts: 4,899 |
Atmospheric conditions matters. And so does height above or below sea level. And running on as little gas as possible is to your advantage. Water weighs 8lbs a gallon, and I dunno what gas weighs, but full gas tank would slow you down. And don't rely on published performance figures. Those are done under weird conditions usually hard to duplicate. ------------------ Dan Parmelee TheContourGuy@aol.com95 SE ATX KKM 24V HIGH OUTPUT badging SVT E0 wheels/tires yellow calipers CEG sticker OF's TH fix HyperWhite high beams CoolBlue low beams drilled metal pedals faux metal grille http://hometown.aol.com/thecontourguy/contour.html
Posts: 4,899 |
By the way, 17.45 is really bad for an SVT. My 95 SE with an AUTOMATIC can run a 17.8! Also, did you powershift? And a short throw might shave a bit of time off. ------------------ Dan Parmelee TheContourGuy@aol.com95 SE ATX KKM 24V HIGH OUTPUT badging SVT E0 wheels/tires yellow calipers CEG sticker OF's TH fix HyperWhite high beams CoolBlue low beams drilled metal pedals faux metal grille http://hometown.aol.com/thecontourguy/contour.html
Posts: 350 |
With these Transmissions in these cars, I would only recommend power shifting if your car is still under warranty. Short-throw would work, but when shifiting just shift as fast as your ass can shift, if your on a stock shifter. ------------------ Jay (Intersection Killer) 00 'BARTENDER! A Black&Tan' SVT Contour Home Sweet Home www.SVTperformance.com
Posts: 42 |
i did power shift, and i have a 100,000 mile warrenty so i'm alright in that aspect. i also just got a new trans put in a week before i took it to the track. i put about 700 miles on before though. i had less then a half a tank of gas too. something is wrong with the car. has to be, cause black98svt ran almost 2 seconds better then me and we were at the same track. well im taking it to the dealer tomorrow, so we'll see what happens.
98.5 black svt. JD Custom Exhaust. "DOWNWARD MOTION" windshield banner. 15.60 @ 87.86mph. 1/4 mile
Posts: 592 |
Ok he didn't tell me he put that back on, last I knew he took it off. Originally posted by Black98SVT: RTS...J has a cold air set up on his ride. It is a nice Alum piece that locates the air filter down and up front in the engine compartment. He had some great launches Sun! I was talking about the guy that came with the Cobra R and a Lightning. ------------------ Ryan 98.5 Silver Frost Contour SVT 5979/6535 Born: May 15, 1998 ~Tweaked Airbox, SRP Racing Pedals w/SVT engraved, Saleen Dead Pedal, Fog Light Mod,B&M Shifter, Ford Door Sill Protectors~ **Mustang Dead Pedal on the Way!!** 84 Thunderbird 5.0 ex 93 Modded SHO SVT Performance.Com
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 592 |
SVT Performance.Com
