I'm new to this forum. If I should be posting this somewhere else, please let me know.
More on Mom's 95 Contour w/ 2.5V6 and AT. Finally got up to check it out. Here's what I found: Tranny fluid about a pint low. Puddle under car in line with front wheels. Can't tell if tranny fluid or oil. Looks too brown for tranny fluid, but that may be part of the problem. (Forgot to check the engine oil to see if that was low and could have been what was on the ground.) Topped off fluid and test drove. First off, speedometer quit the same time the tranny started acting up. Shifts real hard, then for no good reason, downshifts. Sometimes is starts slipping. Prior to getting to where it is now, was experiencing a shudder/vibration at about 35-40 mph right where tranny was trying to shift from 3rd to 4th. Seemed like it couldn't decide which gear it wanted to be in. I am not to familiar with the newer automatics, but know the older ones have throttle pressure linkage. What do the new ones use? I know there are electronics involved, and I have heard of TV cables. Could it be related to this somehow since speedometer and tranny both went out simultaneously? Any help or thoughts on this would be appreciated. Trying to help Mom out and save her some money. Terry? Anybody?
