Posts: 85 |
at what RPM are the secondaries supposed to open? Mine open at about 3500-3750. Just seems a tad high for me. Is this correct? would a mod chip change this?
2000 SVT #1633/2150 many mods, many more to come http://www2.gvsu.edu/~hafnerb/11h/car.jpg "If it doesn't fit, force it, if it breaks, it wasn't meant to fit in the first place."
Posts: 174 |
should be 3400 i believe, but i could be wrong
THIS CAR IS F***ING COOL!
bone stock for now...
Posts: 592 |
3400 when your in it from the get go
4000 when you are just cruising around
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 303 |
My 1999 SVT Contour sales brochure says 3400 rpm for full throttle runs and 3900 rpm otherwise.
Dunno about the regular Duratecs. I think it's a fixed rpm somewhere around 3500 rpm.
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 31 |
I've got a 98 SE, regular Duratec. You can feel it when the secondaries kick in, and it does vary by how much throttle I'm giving it. 3400/3900 seems about right....
JimCat
Posts: 139 |
Posts: 4,899 |
3400rpm at WOT, varies at any other throttle point (4000-5500).
Posts: 1,861 |
What I have understood is 3400 RPM at WOT amd 4000 RPM otherwise. This seems to be what I feel when I drive as well.
One of the changes a superchip makes is more agressive secondary opening. I remember Ray McNary saying that this is what he probably liked most about his Superchip.
Jim Johnson 98 SVT
Posts: 4,899 |
Someone on NECO rigged up a small light to the IMRC and found it engages from between 4000 and 5500 if you're at less than WOT, but I could be wrong.
Posts: 132 |
I always thought that they were at 3750. That's when I can hear them and feel the pull of the car more...
1998 Sliver Svt... #1698 of 6535 K&N Filter Came on the earth on 6-6-1997
