Posts: 1,152 |
Guys, I broke the bolt holding my Aussie Bar to the car (the one that holds the bracket one). I drove around today and it was clanking a lot (go figure) Anyway, I picked up the weldable Brackets that come with the Aussie bar from Spatts house. Anyway, My question is...Is can I weld the new ones right in the old place? Or do I need to make the metel there stronger by addind some steel to it? Or will I be ok if I get them just welded to to where the old ones were (old ones being stock ones). Can you guys let me know. I want to get this fixed on Wednesday. Thanks alot, Joe
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 3,237 |
You MUST weld a backing plate with two holes (compared to the single hole and slot on the stock backing plate). Otherwise you can't fit the bracket correctly. You CANNOT weld the bracket straight to the frame: a) You would melt the urethane bushing b) You would be f'ed if you had to ever take the bar out for suspension work and c) Yhe stock backing plate is simply not strong enough.
After one year, my backing plate has bent downwards on both sides, thus allowing a bit of clunking over some bumps.
This is due to the fact that the stock bracket is just a crap design and it is too thin to start with.
I have to make some backing plates myself and weld them on so I too can use the upgraded bracket I supplied with the Aussiebars.
Posts: 2,906 |
Originally posted by L8 Apexing Aussie: I have to make some backing plates myself and weld them on so I too can use the upgraded bracket I supplied with the Aussiebars. make a few more of those while you're at it, m8
Spattmobili®
Posts: 3,237 |
New Performance Part: Aussie Backing Plate!
Posts: 1,152 |
Hahah cool. Thanks Stazi... I hope an exhaust shop can do this.. Oh ya ..what are you doing the second weekend (Sunday) In Feb.? I think thats when were working on my car.. (Apex-I and stuff)
Posts: 3,237 |
Nothing right now. Are you going to drive up to my house so I can install your A'PEXi?
Posts: 1,152 |
Yeah well I could do that or we could just do it on that Sunday. Dave, Spatt, Me and Hopeing you could come over to spatts house. We got Rogers heater for the day to keep warm. We will be installing some springs/struts, battery relo kit, Boring TB out and hopeing you could install the SAFC that day too... I will be a fun filled day! Thanks, Joe Ps. I am off to get this Sway Bar looked at...I will let you know.
Posts: 86 |
Joe, r u still going to flordia?
havn't seen u online to ask
-Tim
Posts: 1,682 |
Originally posted by SVTJOE1: Yeah well I could do that or we could just do it on that Sunday. Dave, Spatt, Me and Hopeing you could come over to spatts house. We got Rogers heater for the day to keep warm. We will be installing some springs/struts, battery relo kit, Boring TB out and hopeing you could install the SAFC that day too... I will be a fun filled day! Thanks, Joe
Ps. I am off to get this Sway Bar looked at...I will let you know.boring out the tb????
Posts: 333 |
Stazi you better show up!! I can only handle seeing spatt lower one car let alone let him do it again. I have people to do and places to see you know.
Silver 99 SVT It's Stock. Would I LIE?
My cars the Silver one
