Posts: 407 |
Ok, to replace bulbs on the fog lights, do you take off the whole front fender mud flap thingy, or just remove the square tabs direclty attached to the mud flap thingy, because I tried to remove those and its just not happening.
Black 1998.5 SVT with custom "Nascar Damage"
Posts: 195 |
take off the whole splash gaurd
1994 Thunderbird sc True dual exhaust into magnaflows pearl white 245 50 16 up front and 255 50 16 in the rear lowered 1.5 inchs
2000 silver frost contour svt Date of birth 1/4/00 #1178 Date of death 7/27/01
Administrator
Administrator
Posts: 4,527 |
it is easier to just take off the entire splash guard. It isn't that hard to take off anyway.
It's all about balance.
bcphillips@peoplepc.com
Posts: 3,584 |
You really need to remove the whole thing to make it alot easier on yourself. Its about 9 screws and thats it, very easy to remove but you just need to bend it a bit to get it out and in again. If you going with the #885 fog bulbs you will not be sorry Roger R
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 407 |
they have those 885 bulbs at autozone?
Posts: 163 |
If you dont want to take off the whole splash shield, simply take off the two bolts in the fender well and go through there.
99 Silver SVT #1264/2760 SVT124@aol.com
Posts: 6 |
What's special about the #885?
Posts: 3,584 |
Originally posted by JSnySVTE1: What's special about the #885? The #885's are a HUGE upgrade over the OEM foglight bulbs. In OEM form the stock ones, #893's are only 38 watt and the upgrade, #885's, are 50 watts! I know that 12 watts may not seem like alot but wait till you change them over...MUCH BRIGHTER I got Sylvania #885's at PepBoys for $23.00 for both and is one of the best mods to make on the Tour. Roger R 2000 SVT #1253 of 2150 "The striped SVT"
Posts: 469 |
did someone already mention taking off the splash guard? just wonderin.
Shaun
95 electric red ruby interior 2.0 zetec not stock by any means lots o goodies
94 plymouth sundance (the beater)
