Posts: 89 |
i had my friends shop do it for me as they cleaned out my UIM at the same time. trust me take it off. mine was just filthy, black stuff just packed on there. pretty gross. i wouldn't do it without taking it off to make sure i get both sides spottless.
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
Posts: 233 |
Thanks to everyone for the advice. I may try to tackle unbolting the TB - after buying a new gasket, just in case - and cleaning it that way.
I'll try to tackle it this weekend, if the weather permits. Thanks again to everyone.
1998 E1 SVT - Toreador Red Production #4794 of 6535 Build date: 2/25/1998 Mods completed: - Pre '97 sail panels Mods planned: - K & N Air Filter - Side marker lights
Posts: 1,701 |
I think you'll be happy you took the TB off. This is really the only way to get the EGR ports cleaned up and all the gunk out from behind the TB. A 1/4" socket set with a 6" extension is about all you need tool wise. While you have the TB off, cut off the extra screw threads holding the butterfly plate and smooth down the shaft.
Posts: 294 |
When you take UIM off shouldn't you get paranoid about dust getting inside ? Is it a good idea to do an oil change after you done ?
Regards, Kirill 98.5 Contour SE Silver Frost (powered by Duratec 2.5L) Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i \_ Blaupunkt ODx694
Posts: 407 |
Not at all - just make sure you don't have change in your shirt pocket.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 233 |
Might anyone know the part number for the gasket off the top of their head? If not, where would I find said part number?
Posts: 407 |
F5DZ-9E936-AE at the dealer.
