#167730 03/22/02 04:20 AM
mistaks Offline OP
Demon do you know how to do the MAF mod? I did a search and couldn't find anything. I have a 4 cylinder if that helps at all.
95 GL ATX
4 cylinders of fury!
2 1/4 custom exhaust
CTA Intake
SVT Rims
9mm FMS Blue Wires/Nology Plugs
Go Jayhawks!
*Lots more to come*
#167731 03/22/02 08:28 AM
Yes.
However I will not tell you because it is not a good idea at all.
You are talking about cutting out the center post right?
Don't do it!
It will change how the MAF reads the incoming airflow and make the readings unstable and erratic. This can lead to lean spots which will cause engine damage not to mention bad driveability problems.
Now streamlining the MAF post might work for you??? As long as you stay away from the sampling hole/tube.
2000 SVT #674 - Check it out!
Moderated by  Eric L_dup1, louisw_dup1
