#167174 02/10/02 01:44 AM
do i really need to use the resistor and diode recemended in the how-to to wire-up my sidemarkers? how do you guys have yours wired? do i have to use the a-6 markers or would some APC's work ok????
98 T-RED SVT
De-Badged
Bassani Xhaust(uncorked)
H-R Springs
B.A.T. Struts
Ford Blue Brake Calipers
Removed Door Ding Guards
Matching Vinyl on F/Windshield
Vinyl Blackout between front and back windows
Alpine 7871, Punch 55, 2 12" JL W3
altered k-n filter
885's Foglight Mod
B&M Short Throw
Painted vents & misc. int. parts
clear corners and bulbs
Born on 6/15/98
Born @ KC Assembly Plant
#6438 of 6535
A.K.A. The ANTI-RICE SUPERCAR
I got APC's on mine...and YES...use the diodes in the how to..you need it to make it work right...after the wiring..its pretty easy.
NP-T Speed Factory Intake
Magnaflow Race Canisters
NP-T Sniper Intake Pipe
Optimized 4.6 GT TB
Vision Driving Lights
Lo-Tek Pillar Pod
FMS Blue Wires
Clear Corners
Short Shifter
Side Markers
Bullit Door
E
E
Depends how you want them to operate. If you want them authentic as in Europe, flashers only, then you do not need any resistors. If you want them to be on with the parking lights and flash then you need the resisotrs and such.
When I was going to do mine, I wanted them authnetic and only as flashers, so I was not planning on doing any wiring except direct to the turn signals wires.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
I have a set of 1994 Honda Accord sidemarkers and they are ran directly to the turn signal. They only flash with the turn signals. Didnt car to have them running with the parking lights then flash brighter with the turn signals. Depends on what you want. Have fun sending the wires through the firewall. Can be a pain in the you know what.
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
I haven't looked at the wiring, but can't you run a lead from the normal turn signal line...
...or is the power loss from running 2 bulbs too much for it?
Where did you tie into under the dash? The fuse box?
This has been on my list for a while too... The never ending list... :rolleyes: laugh
2000 SVT #674 - Check it out!
E
E
Here is the most widely used diagram for the sidemarkers install:
svt1675@comcast.net
I ran speaker wire up through the firewall to the turn signals where I connected the wires to the blue/orange strip and black for ground. i would recommend testing it all before crimping everything together or you can become very fustrated very fast. good luck.
Sam
AOL users = PhatSVT
1986 Mustang GT
12 second club
Moderated by  Eric L_dup1, louisw_dup1
