Posts: 237 |
A friend told me about a product called '5-minute oil change' (or something similar) that you can buy at Walmart and most auto supply shops.
It is about a one-quart can of fluid that you pour into your engine, just before you do an oil change, and then start the engine and idle it for about five minutes.
It is supposed to clean the engine by breaking down all of the gook that has deposited in the nooks and crannies of the engine.
Does anyone have any experience or comment on this product?
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Posts: 2,683 |
Its called engine flush,good stuff.Basicly a can of Kerosene.Good to do every once in a while.
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 3,223 |
Except that it can destroy seals and gaskets!
-Andy
Posts: 237 |
Originally posted by Andy W.: [QB]Except that it can destroy seals and gaskets!/QB] How does it do that?
Posts: 407 |
I just used an engine flush because I switched over to Amsoil. Dump into the engine and run at a fast idle for fifteen minutes. It clears out all the gunk & stuff that coats the engine.
2000 SVT Black & Blue #205 of 2150 Kenwood Head Unit
2001 SR5 4 Runner 4x4
Posts: 3,567 |
It is a good idea to use the flush every once in a while. It helps to clean deposits from areas where there is not alot of oil movement.
Just follow the directions on the can and you'll be fine.
If you do get a leak its probably becasue the seal or gasket was already worn enough to casue a leak, but it was sealed by a biuld up of gunk on the inside of the engine that was washed away by the cleaner.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 878 |
Originally posted by JSmith: It is a good idea to use the flush every once in a while. It helps to clean deposits from areas where there is not alot of oil movement.
If you do get a leak its probably becasue the seal or gasket was already worn enough to casue a leak, but it was sealed by a biuld up of gunk on the inside of the engine that was washed away by the cleaner. If I understand correctly, the gunk buildup actually causes your seals to shrink, or break down in some way, so It's probably a good idea to clean things out periodically. Of course, if you use a good synthetic, you shouldn't have this kind of buildup.
"Function before fashion."
'96 Contour SE
Posts: 532 |
I have been using synthetic since new...there is no sludge or varnish build-up at all. Otherwise, give it a shot, it does work somewhat.
Dan B.
Posts: 7,329 |
Originally posted by Andy W.: Except that it can destroy seals and gaskets!
-Andy Stay away from any engine flush product! Regular changes and quality oil negate any need for this crap. (I run synthetic so it's a no-brainer not to use it already) It can guarantee fresh new leaks on older cars that use this stuff. Provided the loosened gunk doesn't get clogged in your oil passages.
Posts: 3,223 |
I would only remotely consider one if it was produced by B&G and a pro did it. All the rest are shots in the dark!
-Andy
