Posts: 2,631 |
Warrenty??? Originally posted by Buckshot77: Amen to that. I only got a little while to give that suspension a good work out. Phil, did I tell you I ended up ruining two of the konis in the wreck? One bent the bottom of the strut tube, the other will no longer adjust. Problem is one is driver front (bent) and one is passenger rear (non-adjust). Weird huh
Rick
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 111 |
Didn't know you busted two of them Rick, sorry to hear about that. Merlin, I think it would be a little difficult to get a warranty claim, based on the facts that 1) The struts have been cut apart and converted to coil-overs, and 2) They are physically, externally damaged. Worth trying I suppose, especially on the back one since it doesn't look damaged, but I would be very surprised if you got anything out of Koni.
Now, this whole supercharged 3L thing is very interesting. How soon do you think that will all come together? I'd make another trip to Iowa to see it run!
Phil Frick 2002 WRX Wagon 98.5 SVT - Retired to wife duty
Posts: 2,631 |
ya, I thought I would try  Weird things have happened... So he is building a WRX killer  Hopefully not a 5.0 killer  Yikes... Originally posted by psfsvt: Merlin, I think it would be a little difficult to get a warranty claim, based on the facts...
Merlin
