Posts: 44 |
Could you just get an electronic boost controller to allow two stages of boost levels or a progressive boost increase?
-Chris
'99 Silver Frost SVT #2582:
- Fondmetal Wheels with Kuhmo Ecsta 235x45x17
- Ground Control Coilovers with Koni struts (on rear)
www.contiqueopedia.com <-- just beginning construction
Posts: 1,695 |
Needs more turboXS DTEC BC-Pro.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 5,810 |
Geezus...bastage!  You scared the crap out of me.
See My Mods
Posts: 431 |
That was my intentions to make people jump to the negative conclusions .........lol  I just having some fun with the board but beleive me I will get a electronic boost controller. But seriousily tires will only give me some gains but not near as much as third wants to do. But how crappy is this you have to wait till 85mph before you can apply the power. On the streets that is over the speed limit and the quarter mile is like the last 100 ft nah but of course the track are sticker too so maybe there I will get to use 15 psi and more. I will make that my project to get grip even if the fenders have to be modified.
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 5,810 |
Hell Yeah. You should definitely do that. THat is the one area people have really neglected to improve on significantly.
See My Mods
Posts: 1,860 |
I'm assuming Burrita that you already did the solid mount adjustment to the rear motor mount that Keith came up with? That helps tremendously, Kontofosho has it and gave it positive feedback. The next mod I was going to do if I kept my car was figure a way to triangulate the front end to stiffen it up. I also welded plates to the control arms which definately stiffened those up. How about sub frame connectors? Have you done those yet? 16 gauge rectangular steel is what I used. It definately stiffened up the frame. You just may need to stare at the front end for a while until you come up with something brilliant to put the power down.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 431 |
I do have the solid motor mount that keith came up with I also have polys in front and teh wheel hop is gone. So I am not sure if two tires spinning would justify stiffening up in s atraight line. If only one did then maybe the flex would cause that. This morning when it was cold It did it so bad I left black marks at a 4K punch to redline and then I smelt rubber afterwards but it still pulled like a monster too. I will try to do fender add-on if possible first.
ported heads
13.2 @ 107 mph
Posts: 638 |
you could always try running on drag radials, you will have to keep the car out of the rain, but with your traction issues it sounds like you should do that anyway.
another option is to try finding a lower ratio final drive gear; not only will it help with traction, but the increased engine load will spool your turbo sooner.
87 Mustang GT 5.0L TURBO
Posts: 937 |
Originally posted by Pope: another option is to try finding a lower ratio final drive gear; not only will it help with traction, but the increased engine load will spool your turbo sooner.
I asked Terry set up my tranny that way. Even with Torsen I'm sure I'll have the same traction issues. Makes for a demmanding (and exciting) ride I'm sure.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Posts: 5,810 |
So where is the video of 14psi?
See My Mods
