Posts: 431 |
Ok I will set it up today watch for it tonite
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 5,810 |
Cool. It would be really nice if you were whipping a corvette or something at the same time.  Or better yet a Dodge Neon SRT4, WRX, or any of the other cars that people drive around thinking "I'm Gods gift to racing..." something like that.
See My Mods
Posts: 431 |
uploading video now on streetfire check video section
ported heads
13.2 @ 107 mph
Posts: 359 |
Originally posted by Keyser Soze: I'm assuming Burrita that you already did the solid mount adjustment to the rear motor mount that Keith came up with? That helps tremendously, Kontofosho has it and gave it positive feedback. The next mod I was going to do if I kept my car was figure a way to triangulate the front end to stiffen it up. I also welded plates to the control arms which definately stiffened those up. How about sub frame connectors? Have you done those yet? 16 gauge rectangular steel is what I used. It definately stiffened up the frame. You just may need to stare at the front end for a while until you come up with something brilliant to put the power down.
you may also want to try some tubular control arms with solid mounts, that would definitely help the rigidity.
yes... I am a cougar owner trolling on your board.
Posts: 227 |
here's my plan for rigidity.
take the motor out, put it in a go kart, or something ugly and small, like a festiva.
follow a cobra driver home, steal his car, bring it to my garage. weld up tubular steel the length of the car. take the rear suspension out of the cobra, bolt it up to the contour subframe. yank the engine, and wiring. put it into teh contour, however it fits. balsa wood, elmers glue, welding steel in, pop cans, hockey sticks, whatever to make it fit. cut a massive hole in the hood where the ported eaton will stick out, for extra cool points.
bring the cobra back, pulled by the festiva, with a sign that says thanks for the drivetrain, here's a festiva.
spank everyone down on the strip next weekend. lol!
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 7,100 |
I'll take a 3.0T in a go-kart, thank you!
Posts: 21,197 |
Scott's car broke it easily. Whomever did it did an ugly job. Not a bad idea though if done correctly.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,336 |
Posts: 4,141 |
Originally posted by TRicker: take the motor out, put it in a go kart, or something ugly and small, like a festiva.
FYI my B6T Festiva will own you
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,210 |
Originally posted by todras: Originally posted by Keyser Soze: I'm assuming Burrita that you already did the solid mount adjustment to the rear motor mount that Keith came up with? That helps tremendously, Kontofosho has it and gave it positive feedback.
Whats the solid mount adjustment???
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
