car: '96 GL 2L auto.
problem: o/d light flash, shift bang
*(thanks for all the help I have received from this forum)
CD43 Ford called "Batavia"
Had problems early on...1994...when used with Ford Probes.
If you want to be enlightened see TSB 93-18-10
DTC codes: use EEC IV test connector, not MECS connector
(which one located under dash?..and location of the other?)
TFT--Transmission Fluid Temp.Sensor.
(anyone hear of problems with that sensor?)
(If you turn the o/d off) would it be ok to drive in the 3rd gear at 55mph?
See o/d light flashing..but no check engine light. Why?
Don't the DTC codes and CEL codes work together? For example, bad torque converter codes are P1741 to P1744.
Ford said I may have a bad T.C...but I never saw a check engine light.
thanks..
