problems: o/d light flash (highway only) and bang shift
I understand this problem...with great help from the members of this forum. I will do the 3x drain and fill and probably change the TSS. But nothing major.
I want to use an ATF additive. Any thought on this? Which brand name and how much too use? I read that a product called LubeGuard is pretty good. And what about Lucas?
if your tranny is fine after you change the TSS and change the fluid I wouldn't use any additive. Additive is usually to cure a problem (rough shifting, slipping, etc..)
I added 1/2 a bottle of Lucas Trans fluid and installed a aux cooler. It cut the trans operating temp big time. The CD4E is bad for overheating. I didn't have any problems before. But, it has never shifted better.
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
