Posts: 67 |
Yes, I did search, and I've found lots of suggestions on which thermostat to use for a hot or cold running zetec. My question is, what is the OE spec thermostat's temperature? My service manual says 195 and I'm just trying to confirm this so I can get the proper replacement. Engine temps are fine, just want to replace it to be safe.
Posts: 498 |
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 67 |
Thanks, I thought so. Is it even possible to buy thermostats hotter than that?
Posts: 498 |
i don't think so, You can buy a 180 degree though.
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 67 |
When opening the radiator petcock, does all of the coolant in the system really drain? Or does a lot remain trapped in the head, block, and heater circuit?
Posts: 410 |
When you drain it from the bottom it almost all comes out. You can raise the rear end to help aid it as well.
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
Posts: 67 |
I'm just wondering because in the coolant flush how-to it claims that some remains trapped in the block and has to be drained by loosening the temp sender.
I guess this isn't the case?
Posts: 410 |
Some could stay in the water jackets in the head. Pull the thermostat housing apart at the same time and find out.
180,500km's so far.
Posts: 6,910 |
of course some is going to get stuck in the engine, nature of the beast ... there should be drain plugs on the block for this reason. If you want to make sure you have it all out run some water from a hose through the system until it comes out clear ... then you are going to mix the coolant with water anyway so go from there ...
- 95 Mystique LS - Zetec/5spd
Posts: 410 |
I wouldn't use tap water from a hose in the cooloing system. Too many minerals in there. I only pure boiled off water to cut down on hard water deposits and scaling in the system. That is a great way to plug the rad and heater core.
180,500km's so far.
Posts: 6,910 |
Originally posted by SquareHead: I wouldn't use tap water from a hose in the cooloing system. Too many minerals in there. I only pure boiled off water to cut down on hard water deposits and scaling in the system. That is a great way to plug the rad and heater core.
i use distilled water when mixing coolant to 50/50
but I can see your point with flushing it ...
Posts: 67 |
Problem is, flushing with distilled water leaves some in the block, thus making the balance of water to coolant more than 50/50...
I wonder how much to adjust the mixture to compensate for this?
Sorry, I'm just obsessive about things being done exactly right.
Posts: 6,910 |
Originally posted by mcgarvey: Problem is, flushing with distilled water leaves some in the block, thus making the balance of water to coolant more than 50/50...
yeah I get your point, I don't think that much will stay, i bet if you mix at 45/55 it would come out 50/50 in the end
Posts: 67 |
Sounds like a plan. Next time I'll just make sure to drain and refill my coolant every year so I don't need to worry about flushing.
Posts: 1,231 |
sounds like a bit of overkill, does it not? Maybe every other year.....
95 Merc Stique
Zetec 2.0 Auto
Posts: 67 |
Costs $8 annually and it's less work than an oil change. Probably overkill, yes, but I dont mind.
