Posts: 7,117 |
You guys get descent mileage. I used to get 28 to 30+ on the highway in my V-6 Contour, but the V-6 Mystique is getting about 22mph no matter where/how I drive. Same computer code, new Autolite plugs/wires just like the Contour, UIM/LIM has been B-12'd a couple of times, good maintenance on everything else. I've got mystery mod, no CELs, & SVT exhaust. I've tried stock air filter setup with various filter brands, and am now running open element for the last 8 months or so. No difference. I'm gonna try swapping out the fuel pressure regulator for a fresh one & performing a full UIM/LIM rebuild. Soon as I get time...
Posts: 44 |
Originally posted by TourDeForce: but the V-6 Mystique is getting about 22mph no matter where/how I drive.
You should try changing gears, I'm sure you'll do better than "22 mph"
00 Silver Frost CSVT
#1136/2150 Born 4 Jan, 2000
Posts: 1,882 |
Originally posted by TourDeForce: You guys get descent mileage. I used to get 28 to 30+ on the highway in my V-6 Contour, but the V-6 Mystique is getting about 22mph no matter where/how I drive.
My gas mileage has begun it's descent as well. I used to get decent figures, but a clogged O2 sensor has reduced it severely. I used to get 29 on the highway. I think it's dropped to about 24-25. I've only been able to break the 30 mpg barrier once or twice. Very frustrating! But then again, I'd MUCH rather sacrifice 1-2 mpg for ice cold A/C!! (I'm a sissy that way! 75° hits, and the A/C goes full blast!)
Posts: 21,197 |
I average about 23 mpg and about 280 miles per tank in my 98 E0. I fill up when the needle hits the E line. Sometimes the gas light comes on and sometimes it doesn't. I should have at least 2 gallons left in the tank according to my calculations when I fill up. I'm not going to chance it and see if I can go another 30 miles.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 7,117 |
You've been stalking me just waiting for me to slip! Damn Nazi!!
Posts: 21,197 |
I have 3 new O2's. The only other things I could do are clean the UIM/LIM and get a new fuel filter. The manifolds were supposedly recently cleaned.
-'96 SE MTX 3L
Posts: 3,709 |
guys are getting way better than I am. With mostly hiway I get about 24mpg. In the city its right around 20  I dunno whats going on. I know that I am running a bit lean, but common!
Originally posted by Chickens: Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 1,882 |
Part of getting the higher mileage is the way I drive. I almost always keep the RPMs low. I'm usually in 5th gear by 30-35 mph. Sometimes I'll shift skipping gears. Often 1-3-5, sometimes 2-4-5. Doing this I discovered the V6 has just enough low-end grunt to SLOWLY get the car moving from a stop in 4th gear.
Posts: 1,231 |
~25mph highway on the mystique ~21 (70% highway) on the GTO
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
Posts: 140 |
Still the usual consistant ~450kms/tank while running on Sunoco 91, usually see 500kms /w 94.
1999 Black/Tan CSVT
#2658 of 2760
201,000+km
- K&N, Magnecor race wires, Optima red top, BAT Euro Kit, KVR CF pads, PIAA Plasma Ion bulbs.
1989 Yamaha FZR600 - 40,000+km
- K&N Pods, Stage 3 Jets, V&H 4-1 exhaust
