Posts: 5,810 |
So just to clarify, is this question you have concerning your contour or your Taurus? AND Does your contour already have the 3L in it or still 2.5L? Because if you only have a 2.5L in your Contour, just swapping in the 3L with the contour heads/intakes and stock fuel injection hardware will give you the extra 50 HP you are looking for. You add the other goodies and you will really be Sportin' at that point.  Just check out my website under the 2001 engine swap link
See My Mods
Posts: 8 |
I have already swapped the 3L into my 1998 SVT Contour. I ended up swapping over the complete wiring harness and had to get a new flywheel and ground down a section of the cam and weld washers to the cam to keep the flywheel in position.
After I figure out what I want done with the engine I will replace the cam.
Right now I am stuck driving my daughters Geo Tracker and would like to get a real car running soon.
Posts: 1,746 |
Am I stupid, or just missing something here....You cut and welded washers onto a cam to keep the flywheel in position?
WTF!
2000 Contour SVT
SF - #542 of 2150
Posts: 227 |
yes. i'm pretty confused here too. there might be someone here that's half as smart as me, and i'm a caveman!
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 8 |
Originally posted by posthuman63t: Am I stupid, or just missing something here....You cut and welded washers onto a cam to keep the flywheel in position?
WTF!
The flywheels didn't match up so I got a flywheel off a newer duratec, in order to make this work I had to ground down part of crank. Then I had used lobe spacers which I think arc welded the lobe spacers.
Also before some ass brings in the accusations and questioning my abilities.
USAF Vietnam 1963-1965,1968-1970 (In-flight Mechanic & Navigation) Rice University Mathematics & Mechanical Engineer (Machine Surfaces Turbine) Rice University Millwright Apprenticeship (Journeyman Millwright) University of Texas Chemical Engineer (Petroleum) Lone Star Steel Company Foreman, Grub and Apprenticeship Chrysler Turbine Consultant and Surface Specialist. Royal Dutch Turbine Consultant and Petroleum Engineer. Westing House Turbine Design and Consultation. Halliburton Field Machinist and Surface Specialist Saturn Motors Machinist, Equipment Assembly, Foreman and Surface Specialist Brown & Root Petroleum Engineer and Turbine Engineer Exxon Petroleum Engineer, Turbine Engineer, Surface Specialist. Carpenter and Millwright Association Union Millwright Work
Posts: 1,746 |
you can be God for all I care, the post I replied to, you said Cam as in Camshaft. Not Crank...so I was like wtf.
2000 Contour SVT
SF - #542 of 2150
Posts: 1,943 |
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 8 |
Sorry, I meant to have typed crank not cam
Posts: 1,943 |
the 3.0L
Posts: 1,651 |
Originally posted by maven: Originally posted by posthuman63t: Am I stupid, or just missing something here....You cut and welded washers onto a cam to keep the flywheel in position?
WTF!
In all honesty if you did these major modifications, how come you can't figure out how to get 50 hp from a duratec? If you have already had a sho and a 315hp ohv 3.0liter?? With all this gread education and personal past with modifiying cars?
Since i have never seen a vulcan 3.0liter ever before do anything over 280whp.
This should be a cake walk for you.
I reject your reality and substitute my own.
