Page 2 of 2 1 2
#1632355 08/18/06 04:55 PM
there absolutly no inspection or emision test of any kind in my province
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
#1632356 08/18/06 04:56 PM
Vive la Quebec!
#1632357 08/18/06 05:02 PM
How an o2 sensor works
���?The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. The mechanism in most sensors involves a chemical reaction that generates a voltage (see the patents below for details). The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly. ���?
By not allowing the exhaust gases to pass over the nozzle of the o2 sensor it will not be able to send a signal voltage to the computer and the check engine light should remain on even with the mil eliminators.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#1632358 08/18/06 05:16 PM
Originally posted by BlackE1:
You will still get a mil light if you don���?�t have them plugged into a properly functioning o2 sensor. All the mill does is altering the signal the o2 sensor is sending to the computer making it think the pre cats are working.
Just plug the 02 sensor in, wrap it with something protective, and zip-tie it to the subframe.
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1632359 08/18/06 05:24 PM
So you don���?�t have to have any exhaust gasses pass the sensor to create the voltage reading the computer needs??
#1632360 08/18/06 05:35 PM
It just has to be plugged in (with the MIL eliminator inline) from what I understand. The MIL eliminator gives it the fake readings and it's gotta still be plugged in so the o2 sensor will still be seeing air (although not exhaust gas). Atleast that's how I understand it.
#1632361 08/18/06 05:45 PM
Plugged in at the connector. Correct. There is a lot of O2 (21%) in the air that we breath for the O2 sensor to switch on and off.
Page 2 of 2 1 2
