Posts: 785 |
im got a msds y-pipe used and there no hole for putting the o2 sensor on it that i have on my oem y-pipe
what can i do ?
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 21,197 |
Buy an O2 bung and have it welded in.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 785 |
where can i get that ? what will happen if i dont plug it ?
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 5,345 |
If you don't have mileliminators and you do not put the lower O2 sensors in,
P0136 Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.
P0156 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
If you have mileliminators, you need to plug the connectors in and then find places to attach the O2 sensors.
1996 V6 ATX 96K miles
Posts: 3,637 |
MIL's and then just hang them somewhere in the air.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 21,197 |
-'96 SE MTX 3L
Posts: 785 |
Originally posted by Tourige: MIL's and then just hang them somewhere in the air.
thx it was what i was thinking to do.... less trouble then welding a o2 bung
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 853 |
You will still get a mil light if you don�t have them plugged into a properly functioning o2 sensor. All the mill does is altering the signal the o2 sensor is sending to the computer making it think the pre cats are working.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 785 |
so i got no choice to weld it finaly ?
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 5,345 |
Originally posted by Tony2005: ...If you have mileliminators, you need to plug the connectors in and then find places to attach the O2 sensors.
Edit. Do you have to deal with tailpipe smog emissions? If you do, maybe you should consider not doing the headers.
Read this
