Posts: 5,345 |
Check VSS, connector and wiring from connector to PCM.
From Autozone
1996 V6 ATX 96K miles
Posts: 252 |
Originally posted by Tony2005: Check VSS, connector and wiring from connector to PCM. From Autozone
Ah ha is that in the top of the tranny if it is. that is the one plug on my new harness thatdid not match up and i had to splice my old plug in to my new harness and i bet i crossed the wires
Posts: 5,345 |
Originally posted by icysvt: Originally posted by Tony2005: Check VSS, connector and wiring from connector to PCM. From Autozone
Ah ha is that in the top of the tranny .......
Correct.
Posts: 252 |
Originally posted by Tony2005: Originally posted by icysvt: Originally posted by Tony2005: Check VSS, connector and wiring from connector to PCM. From Autozone
Correct.
ok if i did cross those I didn't possibly hurt that did I
Posts: 5,345 |
Only one way to know. Put it back correctly.
Edit.
For the 1998/1999 SVT, VSS signal is Pin 58 on the PCM connector. And that wire should be White/Violet.
Posts: 252 |
Originally posted by Tony2005: Originally posted by icysvt: .. ok if i did cross those I didn't possibly hurt that did I
Only one way to know. Put it back but wait while I look through the PCM wiring.
ok the old harness had that plug cut and spliced in on it also but the wires weren't the same colors on the new harness so i kinda guessed. I wasn't sure what that was for til now
Posts: 5,345 |
If the old VSS has a tell tale sign of Green/Red wire, then it was from an early 1995 and won't work for you. You will need a new VSS and connector (if you threw away the connector from your SVT when you spliced it) .
Note that the signal should be 0 mph:0 hertz, and 55 mph:125 hertz
Posts: 252 |
well the car had one spliced on the old harness also. the wires on it are red and white but the wires on the harnesses are all purple with a colored stripe
Posts: 252 |
oh and the plug i took off the harness was a wide 4 wire plug with the metal clip that locks it on but with only 2 wires in it. the one to the vss was small and curved on one side i think but looked nothing like the one that hooks to it
Posts: 252 |
ok i took and changed the wires and still nothing. is there a fuse for the vss or do i just need to get a new one?? worked fine before. the wires i have are violet and yellow and violet and black. So IDK???
