Posts: 21,197 |
....'The Aftermarket Myth'...So many owners think that aftermarket parts must be better than OEM,this is not always the case.Take the clutches.Only OEM's have sight of the genuine Ford drawings and blueprints for the parts,an aftermarket supplier has to guess or copy from physical parts.The OEM supplier still,even on service parts to Ford,meet specific QC inspections...OK,they are not as high for sevice parts as parts that go to an assembly plant but never the less they do have 'QC'...most aftermarket have none...No suprise in that, how can you inspect if you don't have the original specs and blueprints from Ford! On clutches the OEM genuine replacement is a LuK...an OEM supplier and even on an aftermarket, say the Sachs clutch. They too are an OEM supplier to Ford. Not so with Spec. I have yet to find an aftermarket clutch that outlasts the OEM units. There is also little point in a stage 1 or 2. If you make real power and torque go to a 3. The first two are no better than a LuK or Sachs unit. THINK before you rush off and buy a clutch that may only last you 30,000. On all non OEM parts it should be 'buyer beware'...Not a plug for Ford or the OEM's but at least they have the specs, data & blueprints to work from, the rest use 'guesswork'...as we can see in the clutch pics, which also shows that 'batch testing', inspection & QC can be a bit 'flakey' to say the least...it's your dosh, be wise when you spend it! TH
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 785 |
but were not talking about 30 000miles here... the clutch was only 6000 KM
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 21,197 |
Originally posted by SVT3Rivieres: but were not talking about 30 000miles here... the clutch was only 6000 KM
And the quality control comments cover that.
-'96 SE MTX 3L
Posts: 8,445 |
so thats why spec clutches always chatter!
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 785 |
they will ship me a new unit as soon as they will received the old one  im quite happy the custmer service was really fast i sent them a email with the picture last night and everything was settled this morning
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 21,197 |
Terry sent me some pics of a Luk with 100k on it. I have a Spec 1 w/o issue and an UR full face kevlar so don't argue with me. LOL! I don't doubt the quality of OEM. I went Spec 1 for a 3L with NOS. Thought it would hold up to more power. This is just to inform ppl.
-'96 SE MTX 3L
Posts: 785 |
who's arguing with you ?  anyway i will get a brand new one soon, hope this one will be ok... oh no.. i forgot i will have to break in again
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 5,810 |
Originally posted by SVT3Rivieres: i will appreciate if somebody can tell me if i can do something for this ?? i need to know asap cause the car is on the lift with everything removed from it...
They should warranty the clutch disk. Call spec and also email their website with copies of the pictures.
Just to be VERY clear, the rivets didn't pop out. They are all sheared off. I don't think you could shear all of them off like that without at least putting a little bit of power to the clutch. Either way, at least you know the linings are tough.
They should warranty that, or the company you bought it from.
See My Mods
Posts: 5,810 |
My oem SVT clutch is still in the parts box downstairs in my garage, 2 years of 3L naturally aspirated and a couple of months with the turbo on it. The linings and the hub held up well but one of the springs had a small piece broke out of it. For the most part I like the stock SVT clutch.
However, with all that said I had a stock OEM SVT clutch in my 98 SVT that I owned that popped at 25K miles. Same EXACT thing as the picture there, the hub rivets stripped out and the dealer put in a new clutch for me. The linings were perfectly good on that disk too. It happened on a fast shifting 1-2 upshift where I popped the clutch pretty quick. Nothing that should have killed that disk either.
So I still have faith in the Spec line of clutches.
See My Mods
Posts: 785 |
its happen to me when i was shifting 1 to 2... but not a so fast shifthing
but the week before i hear 2 time some metal shreading on high rpm (maybe those two ringhole who broke)
my OEM clutch was change at 122 000KM
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
