9
Thats right people, for only $2,495 if you finance or $1,495 if you pay cash, you can run your car on a mixture of 80% WATER and 20% gas and get 100mpg!
"Q. Does it really work?
A. The Gas Advance System simply vaporizes the fuel using the exhaust itself. With a patented system, a magnetic reactor rod ionizes the fuel during vaporization. Internal combustion engines utilize oxygen through air intake and hydrocarbons through gasoline. Your gasoline engine already uses hydrogen, oxygen, and carbons to burn. We simply use catalyst ionization with the reactor rod separator strategically placed in the fuel line, this vaporization process serrate oxygen, hydrogen, and carbons to burn as elements and do it more efficiently. Hydro-carbons, oxygen, and hydrogen burn more efficient through this patented process. "
Come on now, are people really this gullable? Their description sounds more like a nuclear reactor if you ask me...
www.gasadvance.com
"Moore has also accused the American people of being the stupidest, most naive people on the face of the Earth. And after last weekend, he's got the box office numbers to prove it!"
IM PUTTING LIKE 1000 IN!!!@
People and there get rich quick schemes.
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
I already have the plasma set up in my cars fools! 500 MPG and 500hp beoatches!!!!!!!!!!!!!!!!!!!!!!!
W
W
Didn't Myth Busters try some of these things out? As I remember the only alternative fuel they found that worked was used vegie oil.
1999 Contour SE Duratec ATX My feet and the Stra�?Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
all on 3 cylinders right? wasn't part of the story that you could unplug the spark plugs and it would continue to work like normal.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
X
X
This reaks of powdercoatman........
Originally posted by Chickens:
Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods 98 E0 SVT~ sold
This doesn't even make sense. In order to do this one would have to generate a magnetic field. They don't mention anything about charges other than the ionized hydrocarbons, which doesn't make sense at all. This thing claims to ionize basic hydrocarbons, which are going through phase changes!?! WTF. Ioniziation usually yields some sort of energy transfer be it through work or temperature. Furthermore, thermo tells us that during phase change temp can't be done on these molecules, i.e. if you look at a phase change graph, you'll notice that when vaporization occurs, something like ionizing these molecules wouldn't be possible, thermodynamically.
Furthermore, WTF @ catalyst ionization?
Yeah, this is a great product. I'll take 2.
99 Black Contour SE Sport
WTF?? That's too much reading for me today.
2004 Ford Freestar V6 Boogity Boogity Boogity, Let's go racin Boys!
NASCAR births the stupidification of America.
Case in point:
* Marine Officer Candidate * My Cardomain Page 1998 EO Black SVTC #3388
dude, this plus that little f*in pill, plus a couple tornado air intake things, and you'll be at like a google miles per gallon.
What do you mean, rhetorical question? 1998.5 SVT --> http://www.cardomain.com/ride/2155561/1 #4619 of 6535, born Feb 18, 1998. i'm a smarta$$, don't take it personally
