Posts: 1 |
so i am no longer able to afford my 2003 dodge neon, so its time to sell that and get something cheaper
well first off, i am only getting this car to last me about 2 years, until i graduate college, so it needs to be able to last that long..
it is a 1997 Ford Contour GL sedan with 242K miles on it..
the contour has pretty much everything new except internals, it has a new battery, new tires, new alternator, new water pump, new radiator and hoses, used transmission with 80k miles on it, new tires, all power accessories work good, pretty much all the major components except for internals are new. all the miles are highway driven, as the owner has a job about 50 miles from here, so it was driving 100 miles per day, and thats it, they have another car for stuff around town. i know the owner, so they are good for their word.
i guess my question is, does the contour just have too many miles, or do you think it could last a few more years?
Posts: 21,653 |
What's the price? I'd give em no more than $800.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 96 |
bobby-
IF (and it's a big if!) the price is right, then sure why not- you apparently won't be keeping it very long.
know, however, that a lot has to do with how methodically the car was maintained. also, whether it is a 4 or a 6.
before you jump on this one car you are familiar with, if you have decided that contiques are in fact in your future, you ought to shop just a little to see what else might be out there in your price range. check the for sale ads on this forum....look at mystiques (generally speaking, somewhat up the marketplace in terms of standard equipment but otherwise built on the same platform). who knows, you may be able to get a little more for your money.....and maybe lower miles!
lakeside
on a lake in middle tn
'98 mystique ls duratec atx
de-badged, pin striped
pre '98 sail panels
b pillar black out mod
silverstars- turns and highs in lows
fogs on with parking lights mod
Posts: 5,143 |
lakeside
plus if its an ATX your skrewed... No more fluid for the CD4E will be manufactorer anymore. Whatever is out there is all that is left.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,456 |
I'm not sure about that, but you can get plenty now. Millions of vehicles use the Dexron III/Mercon.
Posts: 5,345 |
Welcome bobby 7  .
Originally posted by AliasJerkââ??¢: ...plus if its an ATX your skrewed... No more fluid for the CD4E will be manufactorer anymore. Whatever is out there is all that is left.
The statement above by Aliasjerk is incorrect.
Mecon V ATFluid superseded Mercon ATFluid (which was used for many years) and is the recommended fluid now.
From TSB #06-14-4, dated June 29, 2006
"ISSUE:
MERCON�® Automatic Transmission Fluid is being replaced by MERCON�® V as a service fluid.
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCON�® can now be serviced using MERCON�® V or MERCON�® Automatic Transmission Fluid or dual usage fluids labeled MERCON�® / MERCON�® V. After July 1, 2007, MERCON�® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory."
1996 V6 ATX 96K miles
Posts: 2,542 |
so wtf are all the people that need that fluid
going to do i have an atx im worried
also im not in a position to buy a case of the fluid at this point
Posts: 5,345 |
You use Mercon V.
Once again, per TSB, "Beginning immediately all automatic transmission / transaxle applications requiring MERCON�® can now be serviced using MERCON�® V "
Posts: 5,143 |
Originally posted by Tony2005: Originally posted by GS474: so wtf are all the people that need that fluid
going to do i have an atx im worried ...
You use Mercon V.
yeah, my bad. I misread the service announcement. I thought they were replacing the trannie fluid, and there wasnt going to be a suitable replacement for the CD4E... Sorry to cause any confusion.
TEIN H.Tech Springs
Posts: 2,542 |
