First off, my car has a known noisy throwout bearing. I can hear a rattling sound at idle and if I push the clutch in it stops, let clutch out, it resumes. Clutch also seems to engage higher up in the pedal travel than it used to. I don't think it will be too long before it needs replacement.
The issue I'm more worried about is that for a while now (about as long as I've noticed throwout bearing noise) I've had a noise that sounds a lot like engine ping between about 4,000-5,000 RPM. I can hear it whether I am really getting on it, or just driving normally but winding it out a little bit more between shifts.
Anyway, I started out with a good MAF cleaning tonight just to make sure (this cured a ping I had in the past), and then went for a ride. I can make the car make all kinds of metallic rattling noise, right between about 4,000 - 5,300 RPM, but at other RPM's I don't hear it.
The weird thing is if I put the car in 5th gear and bury the throttle, with the engine at about 2,000 RPM or so, I can't get it to make the sound at all. My experience with pinging engines has been that they will ping the loudest under a heavy load, which was what I was trying to simulate by flooring it in 5th gear at a really low speed.
The engine seems to have the same power as it always does, it's just noisy between those higher RPM's. Since the noise sounds similar to engine ping, I want to be careful so I don't destroy the engine. I need to use this car for a drive through some mountain roads and if I have to take it easy on it and keep it in the lower RPM's the whole time, it is going to be a very slow, long trip.
I'm wondering if this noise could be due to my throw out bearing, or if it is actually engine ping? Maybe I should throw some high octane gas/additives in the tank to see if the noise stops? Thanks for any info!
96 Contour GL 2.0L MTX with Early SE 7 spoke wheels, SE sideskirts, Koni Sport Kit 70 Mustang Sportsroof with mild 351W and '01 Mustang GT wheels
