Posts: 84 |
Hello,
I just purchased an Autometer A/F gauge and all I have left to do is connect the purple wire to the Red/White wire under the hood. I wanted to check things out before I made the final connection.
I have been searching the forums on people who have already done this, and it seems our cars have narrow band o2 sensors and it is better to use a wide band. I currently have all the cats in place on my car, and I am willing to put in a wide band to get a better measurement.
So, I have a few questions which I havent seemed to find answers by searching the forums:
What is the difference between wide and narrow band? Is it the output voltage range higher or is there something else?
Can I replace a stock upstream O2 sensor with a Wide-Band? Or will this freak out the computer? If I can do this, what make/model do I purchase?
I would assume I want to get a reading off an upstream O2 sensor so this way the cats dont interefere with the true A/F reading.
Thanks for your input, and forgive my ignorance!
Posts: 3,637 |
are you running FI? (nitrous, turbo/supercharger)
you want to mount the wideband right at the joint of the y-pipe before the flex pipe and main cat. This is granted you dont have pre-cats.
Most people use a wideband because with a wideband, if your car goes lean and lets say, you need to stop spraying nitrous it will tell you pretty much right away. By the time a narrowband shows you that you are running lean it is to late.
Also a wideband will tell you your exact A/F ratio.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 7,100 |
You haven't mentioned your INTENTIONS for having a wide-band O2 sensor, other than "getting a better reading".
Were you asking if placing a wideband in the narrowbands spot will somehow help the PCM to make better choices?
Unless YOU are going to view the information, and adjust your driving based on such, the wideband wouldn't do anything *helpful* that a narrowband couldn't.
The PCM can't utilize the wideband to any scope that it will change your fuel strategy for any benefit. Also, unless you are running some sort of FI, or nitrous application, a N/A platform will not NORMALLY see a USE for a wideband, especially if you are on the stock tune, with stock components.
'99 CSVT - Silver #222/276
Posts: 84 |
Ok, Thanks for the replies. I am running N/A with no nitrous, and like I said in the beginning, all the cats are still in place, including the cats in the headers and the main cat after the y-pipe. Everything is, for the most part, stock including the stock tune.
I am mostly installing this for cosmetic reasons, but I am still curious as to how all of this works.
I still dont understand the difference between wide-band and narrow-band.... does 'band' refer to the voltage output range, the response time, or the range of oxygen quantities?
IF it is true what you say about the nitrous, where the stock unit is not "fast" enough to keep up with actual changes, then the band must refer to the bandwidth(or response time) of the output... meaning the voltage output lags quite a bit behind the actual levels in the exhaust. The slow bandwidth (narrow-band) has inherent filtering which sort of averages out (overdamps) the voltage output. Is this a correct statement?
Thanks!
Posts: 3,637 |
Originally posted by hsoverma: Ok, Thanks for the replies. I am running N/A with no nitrous, and like I said in the beginning, all the cats are still in place, including the cats in the headers and the main cat after the y-pipe. Everything is, for the most part, stock including the stock tune.
Thanks!
Just install some LED's in the dash and make them light up in random orders, you will save yourself some money and still look like a ricer in the end.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 84 |
Tourique,
I am so sorry I am so underneath you and so inferior to you. You must be a CEG God, and I am fortunate to even have you write to me or even read my post. Thanks for being so helpful. Your superior intellect and skills are too high for me to understand. We all should all bow down to you because we dont do things the way you want to do them.
Please, all of CEG, bow down.
Posts: 1,516 |
wideband sensors provide a linear reading while narrowband sensors jump all over the place. So with a a/f gauge hooked up to a narrowband you are just going to get lights jumping back and forth from rich to lean.
If you want a more accurate indication of your a/f ratio you can spend $300+ and get a wideband system or you can send you gauge to someone that will chage the voltage your gauge responds too for a more accurate reading. I don't remember the place off the top of my head but i will search for it
here is how they work if you want to know
edit:
Thread covering A/F guages
Cameron
98 Black CSVT #2958
Posts: 3,816 |
Originally posted by Tourige: Originally posted by hsoverma: I am mostly installing this for cosmetic reasons, but I am still curious as to how all of this works.
Tourique,
He was being serious!
All mine does is go back and forth, back and forth, back and forth, back and forth, etc.
About all it does help me with is if the car is constantly lean due to a vacuum leak... then it's red/yellow/red/red/red/yellow/red/yellow/red or just constant red.
Plus it doesn't light up just a single LED, it's like 5 leds swinging back and forth. Kinda like if your tach needle was 500RPM wide...
Posts: 3,637 |
Im sorry, i just dont see the point of wasting money on useless guages that wont do anything for your car.
If you really want; Take that 300 bucks you were going to put into guages, take the 100 bucks for the lotek guage pod, and get a damn dyno tune.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,746 |
Oh stfu the both of you. bottom line is the A/f gauge is worthless unless its a wideband (could have just said that tourige). I own one myself, and until I can afford to buy a wideband, it will be filling a gauge hole in my dash. Besides...blinking lights distract me from noticing fart cans on cars next to me, forcing me to drive with road rage
2000 Contour SVT
SF - #542 of 2150
