Posts: 3,637 |
75 Shot.
Clutch was slipping BAD so we had to bump up a gear on the dyno.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 6,106 |
What gear were you pulling in initially? What gear did you go to? My guess is, you went from 3rd to 4th, where 4th SHOULD be used anyway. I can't see pulling in 5th gear(143mph+), especially on nitrous.  Mark
2000 Black CSVT
Posts: 3,637 |
Originally posted by Y2KSVT: What gear were you pulling in initially? What gear did you go to? My guess is, you went from 3rd to 4th, where 4th SHOULD be used anyway. I can't see pulling in 5th gear(143mph+), especially on nitrous.
Mark
Yep.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,101 |
Are these Mustang numbers corrected to be like Dynojet numbers like most operators do now or just SAE corrected?
Posts: 3,637 |
Originally posted by timeless420: Are these Mustang numbers corrected to be like Dynojet numbers like most operators do now or just SAE corrected?
Those #'s are not corrected to match Dynojet
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 227 |
mucho clutch slippage when i was on the juice, with a 100 shot. if you pull in 4th it actually slipped more for me. i just hit the juice at 5000 instead of 4000 in third and it slipped alot less. either way the best idea is to put a good clutch in it and a 100 shot, so u can be around 300  nice though
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 3,637 |
Originally posted by TRicker: mucho clutch slippage when i was on the juice, with a 100 shot. if you pull in 4th it actually slipped more for me. i just hit the juice at 5000 instead of 4000 in third and it slipped alot less. either way the best idea is to put a good clutch in it and a 100 shot, so u can be around 300
nice though
Yea, ill see how long this clutch will last before switching it. If i get a Spec Stage 1 ill probably bump the shot to a 90.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 227 |
well mine on a 100 shot put the torque up to 260 when slipping, thats pretty much maxing out the rating of the stage 1. i would recommend the stage3, it's perfectly drivable, and holds up to 440.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 9,196 |
That weight of 2950, is that a Canadian "maysurement" or were you on the moon dynoing  BTW it looks like you've got a beast there for sure
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 227 |
oh yeah he does, his sheet spikes when he hits the juice too like mine did. eventually the clutch grabs and pulls but the pull isnt as steady and you in essence dont get the same "run at the rollers" that you would if it didnt slip. he's puttin down more than that for sure.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
