Posts: 3,637 |
75 Shot.
Clutch was slipping BAD so we had to bump up a gear on the dyno.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 6,106 |
What gear were you pulling in initially? What gear did you go to? My guess is, you went from 3rd to 4th, where 4th SHOULD be used anyway. I can't see pulling in 5th gear(143mph+), especially on nitrous.  Mark
2000 Black CSVT
Posts: 3,637 |
Originally posted by Y2KSVT: What gear were you pulling in initially? What gear did you go to? My guess is, you went from 3rd to 4th, where 4th SHOULD be used anyway. I can't see pulling in 5th gear(143mph+), especially on nitrous.
Mark
Yep.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,101 |
Are these Mustang numbers corrected to be like Dynojet numbers like most operators do now or just SAE corrected?
Posts: 3,637 |
Originally posted by timeless420: Are these Mustang numbers corrected to be like Dynojet numbers like most operators do now or just SAE corrected?
Those #'s are not corrected to match Dynojet
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 227 |
mucho clutch slippage when i was on the juice, with a 100 shot. if you pull in 4th it actually slipped more for me. i just hit the juice at 5000 instead of 4000 in third and it slipped alot less. either way the best idea is to put a good clutch in it and a 100 shot, so u can be around 300  nice though
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 3,637 |
Originally posted by TRicker: mucho clutch slippage when i was on the juice, with a 100 shot. if you pull in 4th it actually slipped more for me. i just hit the juice at 5000 instead of 4000 in third and it slipped alot less. either way the best idea is to put a good clutch in it and a 100 shot, so u can be around 300
nice though
Yea, ill see how long this clutch will last before switching it. If i get a Spec Stage 1 ill probably bump the shot to a 90.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 227 |
well mine on a 100 shot put the torque up to 260 when slipping, thats pretty much maxing out the rating of the stage 1. i would recommend the stage3, it's perfectly drivable, and holds up to 440.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 9,196 |
That weight of 2950, is that a Canadian "maysurement" or were you on the moon dynoing  BTW it looks like you've got a beast there for sure
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 227 |
oh yeah he does, his sheet spikes when he hits the juice too like mine did. eventually the clutch grabs and pulls but the pull isnt as steady and you in essence dont get the same "run at the rollers" that you would if it didnt slip. he's puttin down more than that for sure.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 6,106 |
Originally posted by TRicker: well mine on a 100 shot put the torque up to 260 when slipping, thats pretty much maxing out the rating of the stage 1.
specclutch.com rates it at 270. I've hit 289+wtq with no slipping. These clutches are definitely underrated. The stock SVT clutch, assuming it doesn't have a bunch of miles, has also proven to be a good performer. Warmonger was running the stock SVT clutch I believe, on his first turbo setup.
Mark
2000 Black CSVT
Posts: 21,653 |
Originally posted by Klasse Act: That weight of 2950, is that a Canadian "maysurement" or were you on the moon dynoing
Yeah really. I also dyno on a mustang dyno and my weight (INCLUDE THE DRIVER) is 3200.
And of course enter the correct temperature.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,637 |
Originally posted by Kremithefrog: Originally posted by Klasse Act: That weight of 2950, is that a Canadian "maysurement" or were you on the moon dynoing
i didnt exactly know what the weight was, 2950 is about 3150 with a driver so im not much off.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 6,760 |
You should be dynoing in 4th anyways as its the 1:1 ratio IIRC.
Ryan
Trollin!
Posts: 227 |
dynoing on the juice isnt good imo in 4th my car bogged out a bit but of course its untuned too.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 6,106 |
Originally posted by TRicker: dynoing on the juice isnt good imo in 4th my car bogged out a bit but of course its untuned too.
Where is the BS flag when you need it? Running the juice in 4th will not cause any bogging. If you don't have a window switch, then it's not safe on the street either. Unless you have a ghetto-rigged nitrous setup, it's going to perform on the dyno, the same as it would on the street.
Mark
2000 Black CSVT
Posts: 3,637 |
Originally posted by Y2KSVT: Originally posted by TRicker: dynoing on the juice isnt good imo in 4th my car bogged out a bit but of course its untuned too.
Mark
He just wants to blow it up so he can get a 3L
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,651 |
Mark
nooo nooo the dyno is different then being on the street. Cause your standing still
Plus i gain more power being on the dyno
I reject your reality and substitute my own.
Posts: 227 |
lol. everyone can have there own opinion.
and yeah i want a hybrid 3L but i wanna hit 300 HP on the stock motor first, hopefully before the snow flies, just soon enough to pull it apart lol
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 6,760 |
Originally posted by TRicker: lol. everyone can have there own opinion.
Like the opinion to dyno in which gear? Or your opinion about the other idiotic statements you've made?
Ryan
Trollin!
Posts: 21,197 |
But our opinions are 90% proven fact.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,786 |
Originally posted by RTStabler51: Originally posted by TRicker: lol. everyone can have there own opinion.
Yeah, I bet you get more torque in 1st gear!
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 227 |
i probably make more torque than all of you in every gear. ooohh, sick burn (bones) haha
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 3,637 |
Originally posted by TRicker: i probably make more torque than all of you in every gear. ooohh, sick burn (bones) haha
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 227 |
lol you better put a bigger jet in....230.....ha! (kidding, kidding)
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 7,100 |
Let's not start this, again.
You can't SERIOUSLY think that, now can you?
'99 CSVT - Silver #222/276
Posts: 227 |
well maybe more than the people making fun of me in the last couple posts.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 7,100 |
LOL.. I'll give that one to ya!  I bet hitting that button is a RUSH on your car!  I've never ridden in a N02 eqipped car, period. I can only surmise from people saying its more of a sudden jolt than a turbo, etc.
Posts: 227 |
yeah. turbos have more constant pull. nitrous (along with the pull) makes your car rev FAST! my first gear lasts a second if that. and yeah the hit is insane! itll be even better when i get the 12" solenoid to nozzle lines. (compared to the 2 footers) of course its harder on the engine but as my daily driver it evens out because i'm not putting constant stress on the motor like a boosted car. also the gas mileage is still good  if you are going to spring zing next year i bet we can work something out i have never been in a turboed contour either. by that time i plan on having a dual stage plate system like i have been talking about, on a 150 or 200 shot depending on how it runs/revs. im not sure what the most nitrous anybody has put on a contour is but i wanna be the one to make a car run with the most nitrous and have it last quite a while.  we'll see what happens, it could be another 5 minute display of power and detonation. only time will tell haha
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 21,197 |
Countdown to diff. failure.
-'96 SE MTX 3L
Posts: 3,637 |
Originally posted by todras: Countdown to diff. failure.
without a tune i dont think the diff is his biggest problem.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 5,810 |
I'd say its about like driving your car at 3500 rpm part throttle, then just slamming the gas. Only it does that whenever you mash the pedal with nitrous even at 2000 rpm. still, if he's running nitrous at that high of a shot where he equals your power and drawing on a 10lb bottle all you have to do is match him for about 6-7 pulls and then he'll be back to 165 wHP and you'll still be at 350-400. lol That's when you wave goodbye. Of course a good racer won't let himself run short on the bottle.
See My Mods
Posts: 718 |
Originally posted by warmonger: I'd say its about like driving your car at 3500 rpm part throttle, then just slamming the gas. Only it does that whenever you mash the pedal with nitrous even at 2000 rpm. still, if he's running nitrous at that high of a shot where he equals your power and drawing on a 10lb bottle all you have to do is match him for about 6-7 pulls and then he'll be back to 165 wHP and you'll still be at 350-400. lol That's when you wave goodbye. Of course a good racer won't let himself run short on the bottle.
That's why i like to take two bottles when i go to the track. lol
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 227 |
i have 3  yep the bottle sux. and on the 100 shot my car will break loose at about 40 in second. if that gives u any idea of how hard it hits. really though, dual stage will be better. more traction, less of a sudden burst on the internals. warmonger has the right idea probably though
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 60 |
maybe not everyone..hehe
but really, i never like the idea of always having to refill a bottle, plus that turbo sound.....
00 SVT #985
Silver Frost
89 Mustang GT TT
-410.6hp/460.7trq (couldnt pull past 5k-lean)
12.77 @106 Before turbos, 12.82 @120.12 With them
-95 Contour GL, 140K FREE!
-WPI FSAE 05'-06', build a race car, get school credit
Posts: 227 |
haha well i dont mind that nitrous sound either.
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 5,810 |
Originally posted by TRicker: i have 3 yep the bottle sux. and on the 100 shot my car will break loose at about 40 in second. if that gives u any idea of how hard it hits. really though, dual stage will be better. more traction, less of a sudden burst on the internals. warmonger has the right idea probably though
Its funny, but the 3L turbo with only 8psi will rip 1st,2nd, and sometimes 3rd loose. With over 10psi it will rip 3rd if you aren't carefull.
See My Mods
Posts: 227 |
 i just got my safc2 in but i havent done all the settings. i got the hi end mixture tweaked out. i only had to back it off 10% to get my wideband to come off the 10's and into the mid 11's, haha! a little more to go~! she came to life when i took fuel away after 5000
1998 CSVT
MSD dis-4
B&M short throw
Fsvt Euro 17's
Spec stage 3
Posts: 6,760 |
My Jeep Liberty makes more torque than you on the bottle.
Ryan
Trollin!
Posts: 5,810 |
Originally posted by RTStabler51: Originally posted by TRicker: i probably make more torque than all of you in every gear. ooohh, sick burn (bones) haha
Hahaha, yeah. Probably for like 1000rpms.
See My Mods
Highly Medicated Member
Posts: 2,882 |
Originally posted by warmonger: Of course a good racer won't let himself run short on the bottle.
I do miss the bottles. And the car. But the whining noise is a great way to replace it...
Semper Fi
"They've got us surrounded. Poor bastards." -Chesty
Posts: 5,810 |
Originally posted by Trapps: But the whining noise is a great way to replace it...
 Whining from all that ignition interference?
lol j/k
See My Mods
