If you can pull off clear corners that would be good, but with the exhaust you basically could do it cheap (i noticed you saved up all summer) or spend some decent money on a trubendz or magnaflow set up. You maybe want to try to do the easy stuff first, i.e. optimize TB, get the Y-pipe optimized, change the plugs, clean the UIM/LIM, put some 5w20 synthetic in there, and load er up with 91 octane. Also replace your resonator with 4inch round pipe from magnaflow and drop in your K&N intake and you're set. All of the easy stuff should be a little bit more, but well worth it, plus you really get to know your car that way. Do that and then save up for the expensive mods.
EDIT: A mirko would be nice, very nice to be precise.
