Posts: 74 |
ok my 99 csvt has a centerforce clutch and intake but i wanna add full exhaust, performance chip and eletric water pump. with the extra power am i gunn have a prob blowing the trans or diff, or even the drive axles?
Posts: 7,025 |
Anyone could blow the trans or clutch with a stock motor. It just depends on your driving habits. The axles should be fine regardless. The centerforce clutch though...
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 5,143 |
Originally posted by beyondloadedSE: Anyone could blow the trans or clutch with a stock motor. It just depends on your driving habits. The axles should be fine regardless. The centerforce clutch though...
Yeah... Centerforce clutches arent really much to brag about...
An exhaust will give you 3 MAYBE 4 wheel HP depending upon how you do it. an intake... about the same if you are lucky. as for a chip, I wouldnt get a performance chip until you know you are done modding the car performance wise, make it the last thing you do.
Since this really isnt that much power you have nothing to worry about for the drive axels or your clutch. But dont go driving like a [censored] head. The Differential in the MTX-75 is fragile, I think pretty much every single CSVT ower has had to drop their trans and had it replaced or updated with an LSD (which I suggest you do).
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 4,051 |
Originally posted by AliasJerkââ??¢: Since this really isnt that much power you have nothing to worry about for the drive axels
Not true. You can damage drive axles on a bone stock motor just as easy as a modified one. Wheel hop is usually the cause, but not always.
Originally posted by AliasJerkââ??¢: I think pretty much every single CSVT ower has had to drop their trans and had it replaced or updated with an LSD (which I suggest you do).
O Rly?
The stock diff. is not as weak as you always make it sound. IIRC alot of it depends on the year also. I thought I read on here that Ford used a stronger diff. in the earlier MTX-75. Could be wrong though.
The stock diff. without abuse can hold up just fine.
Posts: 6,106 |
And since nobody has mentioned it, I would just stick with the stock water pump. If anything, just replace the stock unit with one that has the metal impellar. It's really not robbing you of any HP. The reason some people are running them, is because of the 3L engine they went to, doesn't retain the cam driven WP.
Mark
2000 Black CSVT
Posts: 21,197 |
Originally posted by Y2KSVT: And since nobody has mentioned it, I would just stick with the stock water pump. If anything, just replace the stock unit with one that has the metal impellar. It's really not robbing you of any HP. The reason some people are running them, is because of the 3L engine they went to, doesn't retain the cam driven WP.
Mark
Nothing but issues with elec. pumps. I have a WP with a metal impelar in the classifieds if you want one.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 853 |
I have my stock Diff. Most of the time you hear about a diff being replaced is when it was being abused. I know they are weak and should have been upgraded by svt. I will upgrade mine when the stock on fails.But i see no sence in dropping the trans unless there is a reason (broken diff).
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 74 |
Originally posted by AliasJerkââ??¢: Originally posted by beyondloadedSE: Anyone could blow the trans or clutch with a stock motor. It just depends on your driving habits. The axles should be fine regardless. The centerforce clutch though...
yea i was never bragging about it, i was just saying so you guys know its not stock thats all.
Posts: 227 |
this is what i read: E0 SVT's have a torque biasing diff. E1's have a torque sensing. (aka, 1 wheel wonder) i heard the E0 diff is better but they changed it because of cost and tire wear increase. i'm most likely wrong, i read it on this site when i was searching for info, im sure of that much.
1998 CSVT
NX stage 1 ford EFI kit
MSD dis-4
B&M short throw
K&N short ram intake
Fsvt Euro 17's
Trubendz 2.5" exhaust
Spec stage 3
249.9 HP 258.2 TRQ clutch slipping the whole time
Posts: 74 |
my e1 tracks both tires true and starit. thanks for the info guys
