Posts: 1,118 |
ive had one since ive bought the car
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
Posts: 3,637 |
Originally posted by mystiquevltwin: ive had one since ive bought the car
+1
My car kit came with one, i want to mount it inside the interior tho, just in case.
Nitrous tends to be a bigger problem with fires..
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 3,028 |
Originally posted by BurritaSVT: I went to autozone to get a fire extinguisher and they had this little bitty one maybe might put out a cigarette if saw one. I looked on ebay nothing much for cars. I like to find a polished on maybe chrome or so. It would look good in the trunk plus I really hate 20k in mods go up in smoke when insuance will only cover my car maybe worth 6000 a fourth of parts in the car.
I read about some that eat up wires real bad and destroy the car even worse then before. I love to have the built in fire system with pull handles but they are like 500 buck at the average.
I bet someone out there has a story or two about electrical fires or fuel ones.
Why don't you get a policy that will cover the extra 20K in modifications in your car? Talk to your insurance company about covering the extra stuff in your car, I bet they will...
Posts: 3,816 |
There are bigger extinguishers that are "permanent," as in you need to run some piping to wherever you think the fire would be at (engine compartment), so that when you push a button or pull the pin in the trunk, it douses the flames. Summit
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by Big Daddy Kane: There are bigger extinguishers that are "permanent," as in you need to run some piping to wherever you think the fire would be at (engine compartment), so that when you push a button or pull the pin in the trunk, it douses the flames.
Summit
Um, yeah, didn't you notice that Burrita mentioned these in his initial post?
Anyway, we use the "permanent" hard mounted systems in our race cars, and have been very happy with them, mostly because we have never needed to set one off. Though, our body shop did release one on accident one time. That sucked because we had to replace the bottle and it wasn't cheap.
Posts: 5,882 |
Originally posted by BlackE1: I got one at Wal-Mart since I have changed a bunch of the electronics (stereo and lights).
They did carry a silver one as well.
i have the same one (probably). its made by Kiddie and is for electrical fires but also does flammible liquids iirc. while i was having some fuel rail isssues in my car (like Steve) i was carrying one around, and scared to death. although i was told that one of these "little" fire extinguishers would do nothing against a fuel fire. (maybe a full size one like you'd have at a school?)
Posts: 853 |
Originally posted by svtizzle4stizzle: Originally posted by BlackE1: I got one at Wal-Mart since I have changed a bunch of the electronics (stereo and lights).
i have the same one (probably). its made by Kiddie and is for electrical fires but also does flammible liquids iirc. although i was told that one of these "little" fire extinguishers would do nothing against a fuel fire.
well the little one was like $10, maybe just get a bigger version for like $30?
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 7,117 |
Originally posted by BlackE1: well the little one was like $10, maybe just get a bigger version for like $30?
Purpose built for automotive applications:
Click-it
Posts: 853 |
The class BC tells you what type of fire it is for. I looked at an automotive class BC and one that was a regular class BC extinguisher. They were the same including the dry chemical they used, only difference was the automotive one came with a mounting plate, a higher price, and was labeled differently on the out side of the box.
I could be wrong but looking at the web site below it seems that it should work for automotive use.
classification of extinguishers: web page
EDIT: Mine must be class ABC and I thought it was only a BC, i will check after work.
WR Headers GMK CAI
Posts: 3,816 |
Originally posted by Rara: Originally posted by Big Daddy Kane: There are bigger extinguishers that are "permanent," as in you need to run some piping to wherever you think the fire would be at (engine compartment), so that when you push a button or pull the pin in the trunk, it douses the flames.
Summit
Guess not...
Read about fire extinguishers here on Wikipedia.
