Posts: 785 |
i will install a DMD this week... do the belt will be the same as the original or i need to change it ? if yes which belt to i need (part number, something ?)
thx
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 310 |
Provided all other pullies are stock and you're not bypassing the a/c (if installed) then yes, same belt.
I'll put holes in him!!
Posts: 1,746 |
Originally posted by SvtTour98.5-3: Provided all other pullies are stock and you're not bypassing the a/c (if installed) then yes, same belt.
x2
2000 Contour SVT
SF - #542 of 2150
Posts: 785 |
it is safe to keep the actual one or should i change it since im there ?
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 7,100 |
Inspect the current belt. cracks in the belt running ACROSS it are normal, and acceptable, as long as the cracks aren't all even with each other. If a crack runs across one rib, then there is another crack on the next rib, but 1/4 apart, etc, then its fine.
when there is a single line across all the ribs it is time to replace. If the belt has cracks running WITH the ribs, replace it If the belts edges are worn, frayed, or torn, replace it.
Get a GATORBACK brand, if you get the chance.
'99 CSVT - Silver #222/276
Posts: 584 |
Out of curiosity, why do you recommend Gatorback? I found two potential part numbers: 4060715 and 4060720. The last three digits are the length of the belt in inches to one decimal place, so 71.5" and 72" respectively. Which one is the right one?
E0 Silver Frost CSVT #3095/6535
Alpine CDA-9851
Posts: 21,653 |
Gatorbacks basically last longer before you have squealing and whatnot because of their design. Goodyear is good at their belts and hoses, go with the gatorback.
And the 715 belt is what you need.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 584 |
Originally posted by Kremithefrog: And the 715 belt is what you need.
That's what I was thinking too. Confusing that the Advanced Auto website has the 720 listed on there as well.
Alpine CDA-9851
Posts: 82 |
Wow, I logged on to ask this same question, and lo and behold, wow, thats random.
-JD. 1996/V6/LX. Killer Bass, & A Few Other Mods.
Posts: 785 |
so i need a gatorback 4060715... somebody know how much is it ?
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
