Page 2 of 4 1 2 3 4
Originally posted by Y2KSVT:
Is that blower going onto your stock block? Wasn't it running a little rough at SZ06?
Mark
everything is being dealt with don't worry.
The stock block can take up to about 450hp, i don't plan to be anywhere near that high so i'm not too worried about it.
Sure should fly after your done. What song we you like me to sing acapella at your funeral "Dust in the wind"?
You're my boy yellow!
DAMN! your car is gonna HAUL!!!
have fun with it!
98.5 Black Contour SVT #5959
Y
Y
Mark
Oh I'm not worried, it's not my car.
I'm fully aware of what a stock 5.0 block can handle. At SZ, I just wasn't sure if YOUR block could handle that. Good to see the motor will be fresh though. Good luck with the install!
Mark
it'll be fine, i hope. once i get this stuff done i'll probably start saving up for a full motor build.
Actually many are getting closer to 550-600 rwhp on the stock bottom end. What you need to watch out for with the boost is the blown HG. I am currently running 15 psi on a mostly stock bottom end, but with arp studs and I am just lifting the heads. I don't have actual numbers, but based on traps and weights I'm in the 450-475 rwhp range. I'll find out later in the week when it finally gets tuned.
what size injector are you running? Good luck with the C&L meter, it's either hit or miss with them. My car ran terrible with the C&L, I switched to a FRPP and the car ran like stock, night and day.
How much boost you running?
00 SVT #985 Silver Frost 89 Mustang GT TT -410.6hp/460.7trq (couldnt pull past 5k-lean) 12.77 @106 Before turbos, 12.82 @120.12 With them -95 Contour GL, 140K FREE! -WPI FSAE 05'-06', build a race car, get school credit
the pulley on there is good for 9-10psi, i also have a higher boost pulley and belt but won't use that anytime soon. i planned to use 30# injectors, i'm hoping the C&L works out.
H
H
H
H
Lookin ggood alex.. lots hawt. I am jealous....
I reject your reality and substitute my own.
CEG road warrior
CEG road warrior
Looks like some fun indeed!
Page 2 of 4 1 2 3 4
