Posts: 83 |
I plan to grab a junk yard dash that will fit my 99 se tour and recover it in a new non warping dash material. could some one help me I need to know what type of padding and cover material I need to use? I know I can use suade or vinyl. I want to go with a light charcoal color in the end. I will also be painting the black trim to match the t-red on the car.
99 Ford Contour SE T Red
XM Radio CD/MP3 Player
Aftermarket Wheel covers
debadged
Posts: 4,051 |
There is no need to do any of that if you are swapping the dash. If you get a dash from a 95-98.5 they will never warp, period.
Posts: 65 |
Originally posted by CSVT1214: There is no need to do any of that if you are swapping the dash. If you get a dash from a 95-98.5 they will never warp, period.
Yeah but I cant imagine how hard that must be to do.
Posts: 4,051 |
Originally posted by Nezerconezer: Originally posted by CSVT1214: There is no need to do any of that if you are swapping the dash. If you get a dash from a 95-98.5 they will never warp, period.
Huh?
You post says that you are getting a dash from the junkyard for your 99 SE. Why would getting a dash from a 95-98.5 be any different to install?
Posts: 65 |
Originally posted by CSVT1214: Originally posted by Nezerconezer: Originally posted by CSVT1214: There is no need to do any of that if you are swapping the dash. If you get a dash from a 95-98.5 they will never warp, period.
Huh?
Thats not my post.
Posts: 83 |
I'm getting a 98+ dash to recover and make look better than a stock look. I am tired with the stock look of our dash I want change. I want to know what padding do I need?!
debadged
Posts: 4,051 |
Originally posted by Nezerconezer: Originally posted by CSVT1214: Originally posted by Nezerconezer: Originally posted by CSVT1214: There is no need to do any of that if you are swapping the dash. If you get a dash from a 95-98.5 they will never warp, period.
Huh?
Thats not my post.
Wow, I don't know how I read that wrong. Sorry about that.
Posts: 4,051 |
Originally posted by jtmccann81: I'm getting a 98+ dash to recover and make look better than a stock look. I am tired with the stock look of our dash I want change. I want to know what padding do I need?!
EDITED to be nicer. This heat is really getting to me big time.
Explain what you mean better?
There is two types of factory dash, 95-98.5 which do not warp, and look better IMO, and theres the 99-00 dash which warps and not as sharp looking IMO.
Posts: 83 |
I will be taking a dash out of a 99 at the local junkyard and pulling the part that warps off and recoving it with a padding and top layer of vinal(preshrunk) or suede to finish off the new dash.
debadged
Posts: 3,637 |
Originally posted by jtmccann81: I will be taking a dash out of a 99 at the local junkyard and pulling the part that warps off and recoving it with a padding and top layer of vinal(preshrunk) or suede to finish off the new dash.
Wrong. GO PRE-98 IT WILL NOT RE-WARP
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
