Posts: 635 |
Thanks Tony2005, know I have to really perform. I pulled F 26 CJB on my Mistake no headlights and pulled F-5 in the BJB, not sure what all that feeds but it does provide +12 to Alternator(probalbly the Field)because the output goes away and of course the ALT light comes on. AND it is on OG wire orange???? Sure be nice to have access to Mitchell's manual again they (I think had full wiring diagrams)to see for certain. I wondering if there are color dulpications ie: engine compartment wiring and cabin wiring???
Need to get yourself a VOM M4gician EH! and remove the battery negative ground this time (?)and check fuses for continuity.
By the way I do not always remove the battery ground when I work on the wiring. lazy Every now and then I damage something?
Paul
I'll try to keep a closer eye here, however the local Ham/weather net is up and possible 80 mph thunderstorms winds coming into the Mansfield Oh area.
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 5,345 |
Originally posted by F111D F: ..s and pulled F-5 in the BJB, not sure what all that feeds but it does provide +12 to Alternator(probalbly the Field)because the output goes away and of course the ALT light comes on. AND it is on OG wire orange???? ...
Yes, Fuse 5 is for the fog lights and the alternator "feed" does go through that, which is one item to check when there is an "alternator not charging battery" issue.
1996 V6 ATX 96K miles
Posts: 635 |
I'm so glad I'm not a Ford tech! Obviously there must be some secret info they get in training classes, how interupt Ford's wiring diagrams?
Tony have you ever seen Mitchell's diagrams of our cars?
Paul
Paul
Posts: 635 |
Just a note for further info F-5 has OG to ALT and OG/blk to the fogs. The diagram shows short line with arrow also from the fuse with no reference as to what is it on either of the diagrams. Yup I funked the Ford tech test!  Glad to have another happy Ceg'er. Paul
Paul
Posts: 5,345 |
Originally posted by F111D F: ...Tony have you ever seen Mitchell's diagrams of our cars?
Paul
No. Just Ford CD, Haynes and Chiltons Diagnostics.
Posts: 5,345 |
Originally posted by m4gician: ...THank you, I replaced the fuse with the extra 7.5 I had avaiable and it worked WONDERS, thank you very very much and I appreciate you going through all the trouble, not just for me but the entire CEG community, you're great!
You're most welcome. Glad it worked out for you. F111D F posted a lot of good info in this thread too and much thanks goes to him as well.
